First of all, I want to advise that English isn't my main language. So, for that, I apologize because it's very rusty.
Second, I read the forum rules and tried to get as much information as I could (I don't use UNIX systems). So, I researched before posting this (I realized you guys don't like people just asking for help withou further information - :D)
Ok, I have a freeNAS machine that I've built from old PC parts (yeah...). To be straight the configuration is:
System Specs:
Build: FreeNAS-9.3-STABLE-201412090314
MotherBoard: ECS G31T-M7
Processor: Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
RAM: 3072MB (memory recognized is 3036MB)
HD: 1 x <ST1000DM003-1CH162 CC49> ATA-9 SATA 3.x device
Network card: <RealTek 8139 10/100BaseTX>
Boot/instalation media: <Kingston DataTraveler 2.0 PMAP> Removable Direct Access SCSI-4 device - 14887MB
OBS.: "Network card", "HD" and "boot/media instalation" are outputs from dmesg | grep -i rl0 and dmesg | grep -i da0, respectively.
As far as I know I'm running freeNAS in a machine below the specs (at least for RAM).
But the point is: from the very first time I start the machine, the system freezes at the point shown in the image attached (or here in case of disappearance)
(Oh, yes... the text is "overflowing" the monitor and I don't how to fix that :()
The weird is that if I just press the reset button or just reboot the machine (not power off) the machine boots normally.
As the machine isn't that masterpiece of hardware I shut it down eventually (due to the age of the parts and its power consumption). Actually, I don't need it up all the time.
But when I need to power it up I'm lead to the same scenario and I have to reset the machine to get the thing work as expected.
I know I have a hardware below the minimum but why it works pretty well after the rebooting (and only after it)? I don't want to reboot this machine every time I fire it up. My main goal is to power up this machine via WoL (which is already working) but with this behaviour I can't use it as I expected.
So, can someone help me? I have saw some threads with this similar behaviour but nothing worked to me.
Oh, sorry if I posted this thread in the wrong place. I didnt find a "Problem solving" or like section.
Since now, I would like to thank you you all guys!
System Specs:
