Ian Bennett
- Jun 10, 2016
Must be something simple with this one, but can't see what! I've set up quite a few FreeNAS 9 systems and find 16GB Sandisk Cruiser USB2 units perfect as a boot device. However, I'm setting up a temp FreeNAS for some SMB shares on a little Acer Revo 70 SFF pc - I know, it's not ideal as a NAS unit, but it's only temporary.
Anyway, the problem in a nutshell is that everything works fine, but with a wierd issue. The only way to boot from the Sandisk flash drive is to remove it, insert another bootable flash drive - in this case another 16GB Cruiser with Windows Server 2016 install image - boot up the Revo and hit F12 to get to the bootable device screen. The Server2016 Cruiser shows up as a boot device and I then swap it for the FreeNAS Cruiser and hit return - FreeNAS then boots up fine and I can access my configured SMB shares . The problem is that I'm back to square one if I need to restart.
Anyone know why the Server2016 Cruiser boots fine, but the FreeNAS Cruiser does NOT appear as a boot device, even although it clearly is when I use the swap trick described above.
I build several FreeNAS systems in exactly the same way using Dell server hardware and have never had this issue so perhaps it's something to do with the Acer Revo BIOS.
