HarryMuscle
- Nov 15, 2021
I have TrueNAS Scale setup behind a Nginx reverse proxy using the following simple location configuration:
Unfortunately all I get is a dark gray empty screen. It seems to initiate some communication with the TrueNAS UI cause it add the "ui" portion to the URL path and the background color matches the TrueNAS UI color, however, it doesn't show the login screen. I'm guessing this is probably related to a wrong location in a header or maybe I'm just missing a Nginx directive to make this work. I'm assuming I'm not the first person to place TrueNAS behind a Nginx reverse proxy so I'm hoping others can maybe share their configuration that actually works.
Thanks,
Harry
location /truenas/ { proxy_pass https://192.168.1.111:8443/; }
Thanks,
Harry
