Bitvise losing login session or not connecting
cookie1338
Hello everyone,
I have been running a FreeNAS system since FreeNAS 9 and I am used to issue smart checks and commands using the bitvise application. I have since updated to FreeNas 11 but sometime after an update on the FreeNas 11 train bitvise started to give me these kinds of errors which sometimes happen and sometimes dont and I can login normally. Other times it disconnects as soon as I open a new terminal console and other times as soon as I enter a command to the console
01:08:35.106 Current date: 2018-08-21
01:08:35.106 Bitvise SSH Client 7.45, a fully featured SSH client for Windows.
Copyright (C) 2000-2018 by Bitvise Limited.
01:08:35.106 Visit www.bitvise.com for latest information about our SSH software.
01:08:35.106 Run 'BvSsh -help' to learn about supported command-line parameters.
01:08:35.106 Cryptographic provider: Windows CNG (x86) with additions
01:08:35.381 Loading default profile.
01:08:39.698 Started a new SSH2 session.
01:08:39.702 Connecting to SSH2 server 192.168.178.14:22.
01:08:39.707 Connection established.
01:08:39.716 Server version: SSH-2.0-OpenSSH_7.5-hpn14v5
01:08:39.720 First key exchange started. Cryptographic provider: Windows CNG (x86) with additions
01:08:39.897 Received host key from the server. Algorithm: RSA, size: 2048 bits, MD5 fingerprint: 0f:00:9b:5a:88:6d:ff:f7:43:ce:65:a8:b9:4c:4e:50, Bubble-Babble: xizic-gusur-hazih-fufes-huzyk-dataz-tygov-zizyh-dylez-punuk-laxyx, SHA-256 fingerprint: ohBz23tKmM+mDi25F2QlmkMTlsrjuAJzyqQ0RVppSMY.
01:08:40.052 First key exchange completed using diffie-hellman-group16-sha512 (group 16, 4096-bit). Session encryption and integrity: aes256-gcm, compression: none.
01:08:40.059 The SSH2 session has terminated with error. Reason: Error class: LocalSshDisconn, code: MacError, message: FlowSshPacketDecoder: received packet integrity check failed.
Can anyone help me?
DrKK
FreeNAS Generalissimo
Fascinating. "Sometimes happens, and sometimes don't". That's very, very, very strange sir.
I use bitvise myself. I do not have any trouble.
Please confirm, on the SAME CLIENT, and the SAME SERVER, you sometimes get this integrity error, and you sometimes DO NOT?
cookie1338
Correct, same bitvise client, same freenas server, sometimes I get this and sometimes I don't but it happens so frequently it is unusable. I have also tried multiple bitvise versions and there's no difference
DrKK
OK, under the "SSH" tab, did you change anything under the "data integrity" or "encryption" choices?
cookie1338
I think I tried to while trying to troubleshoot so I just went back and reset everything in SSH tab
Now I'm getting this
01:41:20.847 Current date: 2018-08-21
01:41:20.847 Bitvise SSH Client 7.45, a fully featured SSH client for Windows.
01:41:20.847 Visit www.bitvise.com for latest information about our SSH software.
01:41:20.847 Run 'BvSsh -help' to learn about supported command-line parameters.
01:41:20.847 Cryptographic provider: Windows CNG (x86) with additions
01:41:21.056 Loading default profile.
01:41:25.885 Started a new SSH2 session.
01:41:25.889 Connecting to SSH2 server 192.168.178.14:22.
01:41:25.889 Connection established.
01:41:25.900 Server version: SSH-2.0-OpenSSH_7.5-hpn14v5
01:41:25.900 First key exchange started. Cryptographic provider: Windows CNG (x86) with additions
01:41:26.065 Received host key from the server. Algorithm: RSA, size: 2048 bits, MD5 fingerprint: 0f:00:9b:5a:88:6d:ff:f7:43:ce:65:a8:b9:4c:4e:50, Bubble-Babble: xizic-gusur-hazih-fufes-huzyk-dataz-tygov-zizyh-dylez-punuk-laxyx, SHA-256 fingerprint: ohBz23tKmM+mDi25F2QlmkMTlsrjuAJzyqQ0RVppSMY.
01:41:26.209 First key exchange completed using diffie-hellman-group16-sha512 (group 16, 4096-bit). Session encryption and integrity: aes256-gcm, compression: none.
01:41:26.214 Attempting password authentication.
01:41:26.226 Authentication completed.
01:41:26.267 Terminal channel opened.
01:41:26.267 SFTP channel opened.
01:41:32.506 Terminal channel closed by client.
01:41:33.356 SFTP channel closed by user.
01:41:34.441 The SSH2 session has terminated with error. Reason: Error class: LocalSshDisconn, code: ConnectionLost, message: FlowSshTransport: received EOF.
01:41:34.449 Automatic reconnection started.
Reconnection attempt is scheduled at 01:41:36.
01:41:36.442 Started a new SSH2 session.
01:41:36.446 Connecting to SSH2 server 192.168.178.14:22.
01:41:36.446 Connection established.
01:41:36.457 Server version: SSH-2.0-OpenSSH_7.5-hpn14v5
01:41:36.457 First key exchange started. Cryptographic provider: Windows CNG (x86) with additions
01:41:36.622 Received host key from the server. Algorithm: RSA, size: 2048 bits, MD5 fingerprint: 0f:00:9b:5a:88:6d:ff:f7:43:ce:65:a8:b9:4c:4e:50, Bubble-Babble: xizic-gusur-hazih-fufes-huzyk-dataz-tygov-zizyh-dylez-punuk-laxyx, SHA-256 fingerprint: ohBz23tKmM+mDi25F2QlmkMTlsrjuAJzyqQ0RVppSMY.
01:41:36.782 First key exchange completed using diffie-hellman-group16-sha512 (group 16, 4096-bit). Session encryption and integrity: aes256-gcm, compression: none.
01:41:36.787 Attempting password authentication.
01:41:36.794 Authentication completed.
Edit: Now fully reset the profile. Same errors as above.
DrKK
Sorry, no. As I said, I have been using Bitvise religiously for years with FreeNAS and the built-in services, and I've not experienced it.
