As this is my first forum post, I assume some kind of introduction is in order. This is my first TrueNAS build, but I have been an occasional forum lurker for about ten yeas or so, while acquiring the courage and knowledge to attempt a build.
I have no formal education in IT, and my previous experience is mostly limited to consumer hardware and PC/Hackintosh builds, so there's that. Please be gentle
While planning my TrueNAS build I had this in mind, and did my best to follow forum advice with regards to hardware recommendations, to avoid getting in trouble. But as my build was planned in 2018, some of those recommendations may be outdated by now.
I think this would be a good opportunity to thank all forum participants for their invaluable contributions - in particular forum regulars jgreco, Ericloewe, Chris Moore, danb35, whose posts have proved particularly helpful!
So, after that introduction, back to my issue(s):
Upon first boot, I received the Supermicro BIOS post code A2 in the bottom right corner of the boot up screen with the big Supermicro logo.
According to official Supermicro FAQ "BIOS POST code A2 means that it can not detect a HDD with a valid partition structure and boot record". I found this strange, as I received this error no matter what drives were attached - or not. So I began to search for other possible causes.
According to the following forum post, there's an issue with the Supermicro X9 mobo's and year 2021, so I first believed this to be my problem, and commenced to update the MOBO BIOS to v. 2.3a as per this recommendation - by all accounts, the BIOS update went successfully:
www.truenas.com
After this, I was able to get into the BIOS and change disk boot order so I could install TrueNAS to the SSD drive attached through SATA.
As I am planning to max out the Fractal Design R5 chassis I'm basing this build on with the max available of 10 drive bays with repurposed 3.5" drives, I have attached two drives through regular SATA, and planning to add the remaining 8 drives through a HBA card (please let me know if this is a bad idea, but I'm assuming it will be OK until told otherwise).
I initially had problems with the two SATA connected 3,5" drives as well - still got the A2 error code - but soon discovered that reformatting the drives from NTFS to ExFAT would fix the issue, and the machine now boots fine from TrueNAS on the SSD with the two reformatted 3,5" drives attached through SATA.
I then commenced to install the HBA card, so I could connect the remaining 8 3,5" drives through this card. (All the 3,5" drives are 5TB Toshiba x300 FWIW).
The LSI 9211-8i card I'm using has been purchased from "Art of Server", pre-flashed to IT-mode FW rev 20.00.07.00-IT. So I'm assuming the card itself should be fine, as it is purchased from a reputable dealer.
To rule out any issues caused by the remaining 8 drives being formatted as NTFS like the two first SATA connected drives, I then reformatted all the remaining drives connected to the LSI HBA card by using a USB adapter.
When that didn't help, I tried to disconnect the SAS connectors from the card, so only the card remains without anything else attached, in an attempt to isolate the problem, but this doesn't change anything. Quite the opposite - now I get the Supermicro boot screen twice, and the first time it is shown, I'm getting the BIOS post code B4. It is just flashing briefly, before the boot process continues (or restarts, not sure which it is), and I'm getting a second Supermicro logo boot screen, but now with the A2 error code.
None of those codes appear without the LSI card installed. Everything seems fine without the HBA card installed. I've attempted to install the card into one of the other PCI slots, but getting the same result.
At this point I'm ready to throw money at the problem by purchasing another HBA card, if that will solve my problem, but I assume I may just be missing some small but crucial detail due to some driver or firmware incompatibility? Or some other glaring mistake, as I'm admittedly a total noob at this.
Right now I'm running out of ideas, so any help and advice would be most appreciated - advance thanks!
System details list
Supermicro X9's and year 2021
Just a quick heads up for those of you running some of the Supermicro X9's and haven't tried going into the BIOS setup in several months... There's apparently a bug in the v2.3 BIOS that will prevent you from entering the BIOS setup if the hardware clock is past 12/31/2020 or some such. You get...
