Chris230291
- Mar 21, 2012
Hi guys. I wanted to follow a guide on setting up byhve, but It seems something isn't set up quite right. When I try to enable it I get this...
Not really sure if my CPU does or does not support this feature, but a compatibility list I found on a BSD forum suggests it should work. (I have an i7 860s) http://ark.intel.com/search/advanced?s=t&ExtendedPageTables=true
In the BIOS I have virtualization turned on, but I cant see anything else that might be related.
Anyone have any ideas?
Cheers,
Chris
[root@Server ~]# iohyve setup pool=Jails kmod=1 net=re1 Your CPU does not seem to fully support bhyve. Missing UG feature on Intel CPU, please upgrade to 5600 series.
Cheers,
Chris
