HugoMcKinley
- Jul 7, 2018
(how) is it possible to set the bootorder of a bhyve vm?
Short info: I want to use MaaS to deploy many VMs. MaaS deploys via PXE boot.
Everything works like a charme, but if an OS is on the VM bhyve doesn't boot any longer with PXE because of the "wrong" bootorder (HDD, PXE).
rEFInd is no solution, because the deployment of MaaS deletes all partitions on the disk.
Is there a possibility to change the zone-config of bhyve to set the bootorder to PXE, HDD? Or any other solution?
Thanks,
Hugo
Thanks,
Hugo
