Bruce Wilfong
- Mar 25, 2016
I have been running Freenas since 9.1 and now on 11.2, over the years a lot has changed with my pools as well as original user I set up, plugin, etc. I basically only run radarr, sonarr, libarr, sab, plex and emby, plus use my freenas server for some basic file sharing. Learned a lot over the years and finally reached a point where I have a degraded pool (12 drives of mixture of 4tb and 3tb drives) that I cant seem to fix easily. So I basically just want to blow everything up and start over (new pools, new pool names, new users, etc.)
I want basically copy my existing data (tv shows, movies, music, home movies, shared files) to a 12TB external drive, blow away everything and install FreeNas frees, then copy the data back over. I dont care about configuration files, or plug-in (installed these a million times). I definitely want to redo my pool(s) and use less hard drives. What I am trying to do is find the fastest and most efficient way to copy my data;
1) hook up an external USB drive to FreeNas, mount and use MC (midnight commander) to copy everything over, re-install Freenas and copy everything back or
2) hook up the USB to my laptop and copy everything over....or does it really matter.
Any suggestions ?
Any suggestions ?
