Best way to get a supermicro out of band (Bios Managment) license key
Ceetan
I would like to get a supermicro out of band (Bios Managment) license key in order to be able to update bios smoothly, But I have no idea where to start, given that i live in Sweden. Does anyone on the forums have a clue?
styno
SweetAndLow
Sweet'NASty
Put the bios upgrade on a USB key and upgrade with ipmi. No key required.
Well, I assume the i3-6100 is the one in use, so that should be fine.
SweetAndLow
Sweet'NASty
Plus some sort of DOS, to actually run the flasher.
I didn't think so. Can't you just flash using the instant flash in the bios.
There's no such thing with the X9 boards--not sure about newer models though.
No, the X10s and X11s don't have that option. The closest thing is the IPMI flasher.
genesys
Here's the easy solution for anyone who needs a license key (sharing this because sometimes you really have no other choice than to update BIOS remotely to get the machine running at all):
Generate it yourself in bash: echo -n 'enter-your-bmc-mac-address-here' | xxd -r -p | openssl dgst -sha1 -mac HMAC -macopt hexkey:8544E3B47ECA58F9583043F8 | awk '{print $2}' | cut -c 1-24
Top Bottom
