Hey All -
So I currently have 8 4TB WD Reds on an older i3 desktop class CPU and plan to move the drives over to entirely different hardware (supermicro board, ECC ram, LSI 8 SATA, etc) and am curious what the best process is. I assume it is:
1) Shutdown the machine properly
2) Move the physical drives from one machine to the other
3) Install a fresh copy of FreeNAS to USB on the new machine
4) Import the Pool?
One thing of note, the new machine will be running VMware ESXI and this instance of FreeNAS will be virtualized. The LSI controller will be passed thru to the FreeNAS instance so there's no middleware between the two. Is this also a best practice?
Thanks!
4) Import the Pool?
Thanks!
