CheeryFlame
- Nov 21, 2022
Hello, I'm tired of having capitalized the first letter of everything. Some pod shell doesn't have auto completion and it's been overall a poor experience using my server this way. It was my first time setting up a server this year and I wished I'd knew about this. I'm feeling like the more I'm waiting the worst it'll be.
Thank you for helping!
*I know that I'll have to reconfigure my applications mount paths, my question is if this can break the app pool at all.
- Would renaming my vdev containing ix-applications from "Name" to "name" will break anything on the app side?*
- How can I rename stuff so I avoid loosing Replication and Snapshot tasks?
- Is there anything to know that it'll break that I should be aware of?
- Export the pool through the GUI. Be sure not to check the box to destroy all data.
- From the CLI, Code:
zpool import oldpoolname newpoolname
zpool export newpoolname
- From the GUI, import the pool.
zfs rename
