steveroch-rs
 - Feb 26, 2020
Thank you for the information!Not really a lottery.
- Shuck only 8TB and above, as WD has no SMR drives there. 3.5" only, as those are the ones with an actual SATA port.
- Before you shuck, run CrystalDiskInfo on the drive, make sure what's in there is something you want.
- Shuck exceedingly carefully, using a credit card or similar flexible prying tool. See YouTube videos.
- Burn that drive in well. https://www.ixsystems.com/community...for-freenas-scripts-including-disk-burnin.28/
- If there are any errors at all, return the drive to its enclosure and RMA it
- Yes, no warranty. WD Elements is only 1 year to begin with, and drive failure rate goes up after year 3 -> anything but a Pro drive is likely out of warranty by the time it fails, anyway. Exceptions are drives that fail early in their life, and that's what burn-in is there for.
I will consider once I upgrade. For now I will populate the 12 bays with 4TB WD40EFRX to get maximum performance. Had the 6TB version for 4years now and it works great. 18TB total storage is more than enough right now for me.
