Hey all, my 1st post so here is my welcome message (will do the real one later) :)
So, I have an old EMC that's activing up, and just a drive replacement is hundreds since they use special drives with firmware, etc. I want to remove that device and replace with 2 servers for fault tolerance. The current use is for our processing servers to write images, etc. to the EMC, then the webservers have it mounted and images for the websites are read from. Nothing to crazy.
I looked at some 1U servers, 4 disk bay's, and just for speed was going to get a raid controller as well. I am watching the into video right now and just noticed 1 drive get's used for the OS, so are people using SD cards to boot from, or USBs, etc not to mention I would like either a fast fix or redundancy on the OS. I want to probably get (4) 2T 10K drives in a raid10 which should prove fast enough, but the next question is the export. The current EMC is connected via fibre and then NFS exported.
So, since this is the n00b forum, I am wondering on;
1. Server. Does FreeNas have issues or anything with any specific hardware? I was looking at a 1U ASUS, duel PS, Intel E3 2G CPU and probably 8G RAM.
2. Raid - LSI is pretty standard I think, any issues with them?
3. Setup. If I currently have 4T of storage, and using 2T, I was thinking (4) 2T drives in a raid 10. Is that the right approach?
4. iSCSI. Still reading on this, but not sure if I should (or can) go this route, so have to read along with a reply from here.
I would like to move on this sooner than later, so not sure if there is a hardware spot you can goto quicker and see what others have bought, as opposed to newegg building, as I want to make sure all hardware is supported. I looked at a full buffalo solution, but they only have 5400rpm drives, and well overpriced!
I appreciate all read/replies.
