nello
- Dec 30, 2012
Suddenly my desktop reports that it can not connect to CrashPlan running in a FreeNAS Jail. The symptoms are reminiscent of an old problem that ended up being caused by a new version of CrashPlan:
https://forums.freenas.org/index.php?threads/crashplan-plugin-wont-start.24243/#post-148959
Symptoms now are these kernel log messages:
Here's the CrashPlan Engine Log:
CrashPlan used to be running at version 3.6.4 but the log seems to indicate that it updated to 3.7.0
Is anyone else having CrashPlan connection issues?
OctoberGroupNAS.local kernel log messages:
> linux: pid 40143 (java): syscall epoll_create not implemented
> linux: pid 40228 (java): syscall epoll_create not implemented
> linux: pid 40280 (java): syscall epoll_create not implemented
> linux: pid 40424 (java): syscall epoll_create not implemented
> linux: pid 40473 (java): syscall epoll_create not implemented
> linux: pid 40608 (java): syscall epoll_create not implemented
> linux: pid 40809 (java): syscall epoll_create not implemented
> linux: pid 40854 (java): syscall epoll_create not implemented
-- End of security output --
CrashPlan is not listening on port 4242 as it should be:> linux: pid 40143 (java): syscall epoll_create not implemented
root@crashplan_1:/ # sockstat -4
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS
root python2.7 11290 3 tcp4 10.10.49.11:12346 *:*
root sshd 11061 5 tcp4 *:22 *:*
root syslogd 10931 7 udp4 *:514 *:*
root@crashplan_1:/ # cat /var/log/crashplan/engine_output.log
Java HotSpot(TM) Client VM warning: Can't detect initial thread stack location - find_vma failed
[01.16.15 10:40:14.554 INFO main root ] Locale changed to English
[01.16.15 10:40:14.555 INFO main root ] **************************************
[01.16.15 10:40:14.555 INFO main root ] STARTED CrashPlanService
[01.16.15 10:40:14.557 INFO main root ] CPVERSION = 3.7.0 - 1388728800370 (201
4-01-03T06:00:00:370+0000)
[01.16.15 10:40:14.557 INFO main root ] LOCALE = English
[01.16.15 10:40:14.558 INFO main root ] ARGS = [ ]
[01.16.15 10:40:14.558 INFO main root ] **************************************
[01.16.15 10:40:14.697 INFO main root ] Adding shutdown hook.
[01.16.15 10:40:14.705 INFO main root ] BEGIN Loading Configuration
[01.16.15 10:40:14.756 INFO main root ] BEGIN Copy Custom
[01.16.15 10:40:14.757 INFO main root ] Directories: [.Custom, custom, /usr/
pbi/crashplan-amd64/share/crashplan/conf/.Custom, /usr/pbi/crashplan-amd64/share/crashplan/conf/custom]
[01.16.15 10:40:14.757 INFO main root ] NOT waiting for custom skin to appea
r
[01.16.15 10:40:14.757 INFO main root ] NO customizations found.
[01.16.15 10:40:14.757 INFO main root ] END Copy Custom
[01.16.15 10:40:14.762 INFO main root ] Loading from default: /usr/pbi/crash
plan-amd64/share/crashplan/conf/default.service.xml
[01.16.15 10:40:14.870 INFO main root ] Loading from my xml file=conf/my.ser
vice.xml
[01.16.15 10:40:15.028 INFO main root ] Loading ServiceConfig, newInstall=fa
lse, version=6, configDateMs=1418655269476, installVersion=1388556100363
[01.16.15 10:40:15.029 INFO main root ] OS = Linux
[01.16.15 10:40:15.316 INFO main root ] AuthorityLocation@18420548[ location
=central.crashplan.com:443, hideAddress=false ]
[01.16.15 10:40:15.317 INFO main root ] Checking Java memory heap max.
[01.16.15 10:40:15.320 INFO main root ] Previous Java memory max heap size
was 1024
[01.16.15 10:40:15.322 INFO main root ] END Loading Configuration
jtux Loaded.
Exiting!!! java.lang.RuntimeException: Unexpected IO Exception constructing selector engine - e=java.io.IOException: Function not im
plemented
[01.16.15 10:40:16.256 INFO main root ] ***** STOPPING *****
[01.16.15 10:40:16.257 INFO Thread-0 root ] Stopping service...
[01.16.15 10:40:16.282 INFO Thread-0 root ] DownloadManager stopped.
[01.16.15 10:40:16.285 INFO Thread-0 root ] SystemWatcher stopped.
[01.16.15 10:40:16.286 INFO Thread-0 root ] Service stopped
r
vice.xml
was 1024
jtux Loaded.
plemented
CPVERSION = 3.7.0 - 1388728800370 (2014-01-03T06:00:00:370+0000)
