T last time I came with an idea for a new build. It would have been purchased over a couple of months but someone mentioned Ebay and cheaper and as former Ebay deal junkie, here I am. I decided that I would go for a small Supermicro 1u x8dtu-f based server from MrRackables. I also ordered the M1015 card, a couple of Cruz 16gb USB sticks and a set of cables for under $300. With x4 2tb drive for under $300 I should be under half the cost of my new build. I did error in buying the M1015 rather than the one port card for half the price. I tried to stick to the recommended gear and I reached out to a forum member who had the x8dtu-f mobo and he was happy about his decision and I've learned to trust community wisdom so hopefully things will come together. Plans: Raidz2 seems to be what people are suggesting, sounds good to me, 4tb storage is twice what I have now. Used processors for the X8 boards are not that pricey so I'll likely pick up a pair of beefy processors and a pair of L processors and see what I like. I also want to hack the case and see how quiet I can get it. I don't know, drill vents mount 120/140mm fans, water cooling, giant passive radiators, at this price if I screw it up I'll buy another. Good times. Thanks for the tips!
