ondjultomte
- Aug 10, 2015
Ok I finally got rutorrent up and running thanks to all the help there.
Now I need to figure out how to install the autodl-irssi scriptfor rutorrent in freeNAS
I'll start with this old guide
FreeBSD
pkg_add -r p5-Archive-Zip p5-Net-SSLeay p5-HTML-Parser p5-XML-LibXML p5-Digest-SHA1 p5-JSON p5-JSON-XS p5-XML-LibXSLT
Note on FreeBSD, you may need to install the following php packages as well:
Installing autodl-irssi
For the rtorrent plugin to work, you need to install the irssi script. After installing the perl dependencies, login as your rtorrent user and do the following:
mkdir -p ~/.irssi/scripts/autorun
cd ~/.irssi/scripts
wget https://sourceforge.net/projects/autodl-irssi/files/autodl-irssi-v1.10.zip
unzip -o autodl-irssi-v*.zip
rm autodl-irssi-v*.zip
cp autodl-irssi.pl autorun/
mkdir -p ~/.autodl
touch ~/.autodl/autodl.cfg
First thing first I got php56 installed but not with all these dependencies, I need to add more extentions/dependencies. How do I do that? Off to google to find the answer.
FreeBSD
- php5-sockets
- php5-json
- php5-xml
cd ~/.irssi/scripts
mkdir -p ~/.autodl
