blackhat840
- Sep 22, 2017
Hello! I'm having a bit of trouble with my Plex Jail. I have a Broadcom dual nic card that works great, however I can't get the jail to use port bge1 for example and the freenas system to use bge0. My freenas configuration is pulling in both.
Even removing the 2nd networking interface from the list and adding it under the jails configuration settings does not allow it to work properly. I've tried DHCP and static, the static set allows my plex to partially work. I can navigate to my plex server but it won't download any artwork for my library, it also won't really stream anything.
The issue seems to be a gateway problem, however the gateway is set just like the Freenas base configuration. I'm just baffled and not sure where to look at this point. The only way I've been able to get this to work is through LACP or disabling one of the ports. My LACP setup is quite buggy at the moment so I'd like to just use each port if possible.
