ATA error count, unreadable sectors, can i fix the hard drive ?
nicosalto
Hi freenas Forum,
I started to get multiple Critical errors on my freenas build recently.
My current built is :
freenas 9.3 - supermicro X11SSM-F - 2x16Gb kingston ran - 2x4Tb WD drive (red)
I searched a bit online and found that i should run :
smartctl -t long /dev/ada1
And the result is:
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E4EL4476
LU WWN Device Id: 5 0014ee 2634c9fae
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Jun 24 12:42:59 2017 SGT
SMART support is: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: (51540) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 515) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 260
3 Spin_Up_Time 0x0027 182 175 021 Pre-fail Always - 7866
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 50
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 027 001 000 Old_age Always - 65586
9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3245
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 50
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 9
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 295
194 Temperature_Celsius 0x0022 115 111 000 Old_age Always - 37
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 6
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 11
SMART Error Log Version: 1
ATA Error Count: 73 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 73 occurred at disk power-on lifetime: 3089 hours (128 days + 17 hours)
ER ST SC SN CL CH DH
40 51 00 e8 8c 18 41 Error: UNC at LBA = 0x01188ce8 = 18386152
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 00 68 8c 18 41 08 5d+04:16:10.917 READ DMA
c8 00 00 68 8c 18 41 08 5d+04:16:04.866 READ DMA
c8 00 00 68 8c 18 41 08 5d+04:15:57.801 READ DMA
c8 00 00 68 8c 18 41 08 5d+04:15:51.721 READ DMA
c8 00 00 68 8c 18 41 08 5d+04:15:48.405 READ DMA
Error 72 occurred at disk power-on lifetime: 3089 hours (128 days + 17 hours)
Error 71 occurred at disk power-on lifetime: 3089 hours (128 days + 17 hours)
40 51 00 68 8c 18 41 Error: UNC at LBA = 0x01188c68 = 18386024
Error 70 occurred at disk power-on lifetime: 3089 hours (128 days + 17 hours)
Error 69 occurred at disk power-on lifetime: 3089 hours (128 days + 17 hours)
# 1 Extended offline Completed: read failure 90% 3100 8349048
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Iam not sure what to do next to solve those multiple errors ?
i was following this article to try to solve the unreadable sectors:
https://dekoder.wordpress.com/2014/10/08/fixing-freenas-currently-unreadable-pending-sectors-error/
But in the comment sections, people seems to say it not really a good solution to solve this.
The hard drive is still under warranty so i could bring it back to the shop if needed. But if this is solvable with some command lines maybe i should give it a go ?
Any advice is welcome! thanks!
nojohnny101
SweetAndLow
Sweet'NASty
Hi freenas Forum,
And the result is:
was never started.
command.
power-saving mode.
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
You don't have scheduled smart tests configured. That's problem 1 an should be fixed. Your HDD is dying and needs to be replaced. That's problem number 2.
Replace the drive. And when you get the replacement installed, schedule regular SMART tests on all drives.
nicosalto
Thanks for the advices!
i will replace the drive and schedule smart test afterward.
