I currently have an AsRock C2750D4I board and i'm using FreeNAS-9.10.1-U4
I was wondering how long and how reliable you have found these boards to be. How many hard drives do you have connected to it?
I recently looked around in the board's firmware under logs and I see constant logs being written
AMID05099E066BE /USR/SBIN/CRON[16550]: (CRON) info (No MTA installed, discarding output)
2 Oct 6 21:52:02 AMID05099E066BE /USR/SBIN/CRON[16555]: (sysadmin) CMD (/usr/sbin/logrotate /etc/logrotate.conf)
3 Oct 6 21:52:03 AMID05099E066BE /USR/SBIN/CRON[16551]: (CRON) error (grandchild #16555 failed with exit status 1)
4 Oct 6 21:52:03 AMID05099E066BE /USR/SBIN/CRON[16551]: (CRON) info (No MTA installed, discarding output)
5 Oct 6 21:53:02 AMID05099E066BE /USR/SBIN/CRON[16680]: (sysadmin) CMD (echo "2" > /var/cache/samba/unexpected.tdb)
6 Oct 6 21:53:02 AMID05099E066BE /USR/SBIN/CRON[16676]: (CRON) error (grandchild #16680 failed with exit status 1)
7 Oct 6 21:53:02
Granted this is just should that be of concern?
I'm aware of this thread https://forums.freenas.org/index.ph...0-d4i-boards-by-disabling-the-watchdog.46968/
and I do have the 0.30 update on my box.
Thanks for your feedback.
-Phil
7 Oct 6 21:53:02
-Phil
