I tested on both 9.10.2 and 10.0 B2.
Both versions had the same problem.
After asking google, i found that there were some users who had same problems.
https://forums.freenas.org/index.ph...0-does-not-work-and-crash-in-rebooting.47299/
https://forums.freenas.org/index.php?threads/shutdown-reboot-problem-nmi-going-to-debugger.43135/
https://forums.freenas.org/index.php?threads/freenas-stuck-on-reboot-logs-inside.48677/
After adding watchdogd_enable = "NO", I did not meet the same problem again. (Only testing reboot&shutdown 1x times)
Therefore, I would like to ask the c236 wsi users that is there any var that i should add into the tunables table?
Many thanks.
Many thanks.
