Caffe Mocha
- Aug 3, 2013
Could someone please check for me if my performance is normal. the specs are as below. the first & second quote are fio test within freeNAS. third and fourth are fio result shared Ubuntu server. I understand NFS within ESXI without slog write performance is going to be bad. still the read and write performance within freenas itself is much lower than expected. read performance in NFS doesn't look so great either.
I had better performance when the set up is 2 vdev in raidz 1 or 2 vdeve in raidz2 among 8 ssds.
if anyone need me to run more tests please let me know. thanks
Motherboard X10DRH-CT with intel E5-2650Lv4 with 8 vcpu dedicated to FreeNAS
RAM: 64G dedicated ram
HBA: IBM M1215 flashed to IT mode x 2
SSD Micron S630DC 960G x 16 2vdev raidz2
within FreeNAS
fio --filename=./test --direct=1 --rw=randrw --refill_buffers --norandommap --randrepeat=0 --bs=4k --rwmixread=100 --iodepth=16 --numjobs=16 --runtime=60 --group_reporting --name=4ktest --size=4G
4ktest: Laying out IO file (1 file / 4096MiB)
Jobs: 16 (f=16): [r(16)][100.0%][r=507MiB/s,w=0KiB/s][r=130k,w=0 IOPS][eta 00m:00s]
4ktest: (groupid=0, jobs=16): err= 0: pid=21211: Tue Jan 30 13:46:10 2018
read: IOPS=129k, BW=502MiB/s (527MB/s)(29.4GiB/60002msec)
clat (usec): min=10, max=205230, avg=123.06, stdev=1173.78
lat (usec): min=10, max=205230, avg=123.19, stdev=1173.91
clat percentiles (usec):
| 1.00th=[ 13], 5.00th=[ 55], 10.00th=[ 56], 20.00th=[ 56],
| 30.00th=[ 57], 40.00th=[ 57], 50.00th=[ 57], 60.00th=[ 58],
| 70.00th=[ 58], 80.00th=[ 59], 90.00th=[ 63], 95.00th=[ 74],
| 99.00th=[ 318], 99.50th=[ 3392], 99.90th=[15270], 99.95th=[23200],
| 99.99th=[50070]
bw ( KiB/s): min=12289, max=52108, per=6.08%, avg=31258.36, stdev=5300.34, samples=1904
iops : min= 3072, max=13027, avg=7814.22, stdev=1325.08, samples=1904
lat (usec) : 20=2.30%, 50=0.17%, 100=95.73%, 250=0.74%, 500=0.28%
lat (usec) : 750=0.05%, 1000=0.01%
lat (msec) : 2=0.10%, 4=0.16%, 10=0.27%, 20=0.13%, 50=0.05%
lat (msec) : 100=0.01%, 250=0.01%
cpu : usr=1.58%, sys=45.65%, ctx=106269, majf=4, minf=28
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued rwt: total=7716685,0,0, short=0,0,0, dropped=0,0,0
latency : target=0, window=0, percentile=100.00%, depth=16
Run status group 0 (all jobs):
READ: bw=502MiB/s (527MB/s), 502MiB/s-502MiB/s (527MB/s-527MB/s), io=29.4GiB (31.6GB), run=60002-60002msec
Within FreeNAS
fio --filename=./rawrite --direct=1 --rw=randrw --refill_buffers --norandommap --randrepeat=0 --bs=8k --rwmixread=70 --iodepth=16 --numjobs=16 --runtime=60 --group_reporting --name=8k7030test --size=4G
fio-3.0
8k7030test: Laying out IO file (1 file / 4096MiB)
Jobs: 16 (f=16): [m(16)][100.0%][r=154MiB/s,w=67.1MiB/s][r=19.8k,w=8586 IOPS][eta 00m:00s]
8k7030test: (groupid=0, jobs=16): err= 0: pid=21604: Tue Jan 30 13:50:03 2018
read: IOPS=28.4k, BW=222MiB/s (232MB/s)(12.0GiB/60027msec)
clat (usec): min=10, max=290249, avg=149.14, stdev=1549.48
lat (usec): min=10, max=290249, avg=149.52, stdev=1550.27
| 1.00th=[ 12], 5.00th=[ 12], 10.00th=[ 13], 20.00th=[ 13],
| 30.00th=[ 14], 40.00th=[ 14], 50.00th=[ 15], 60.00th=[ 51],
| 70.00th=[ 53], 80.00th=[ 56], 90.00th=[ 83], 95.00th=[ 178],
| 99.00th=[ 2606], 99.50th=[ 5669], 99.90th=[16712], 99.95th=[22676],
| 99.99th=[50070]
bw ( KiB/s): min= 3171, max=56298, per=6.09%, avg=13807.54, stdev=9258.56, samples=1905
iops : min= 396, max= 7037, avg=1725.52, stdev=1157.33, samples=1905
write: IOPS=12.2k, BW=95.1MiB/s (99.7MB/s)(5707MiB/60027msec)
clat (usec): min=16, max=309529, avg=943.43, stdev=3701.98
lat (usec): min=16, max=309529, avg=943.89, stdev=3702.59
| 1.00th=[ 20], 5.00th=[ 63], 10.00th=[ 93], 20.00th=[ 149],
| 30.00th=[ 202], 40.00th=[ 251], 50.00th=[ 306], 60.00th=[ 371],
| 70.00th=[ 469], 80.00th=[ 660], 90.00th=[ 1516], 95.00th=[ 3687],
| 99.00th=[ 12387], 99.50th=[ 17433], 99.90th=[ 39584], 99.95th=[ 61604],
| 99.99th=[141558]
bw ( KiB/s): min= 1500, max=23090, per=6.09%, avg=5925.22, stdev=3951.97, samples=1905
iops : min= 187, max= 2886, avg=740.22, stdev=494.01, samples=1905
lat (usec) : 20=37.70%, 50=4.62%, 100=25.60%, 250=10.99%, 500=10.74%
lat (usec) : 750=3.46%, 1000=1.41%
lat (msec) : 2=2.18%, 4=1.42%, 10=1.27%, 20=0.45%, 50=0.13%
lat (msec) : 100=0.02%, 250=0.01%, 500=0.01%
cpu : usr=0.91%, sys=14.31%, ctx=1437406, majf=0, minf=0
issued rwt: total=1702059,730548,0, short=0,0,0, dropped=0,0,0
READ: bw=222MiB/s (232MB/s), 222MiB/s-222MiB/s (232MB/s-232MB/s), io=12.0GiB (13.9GB), run=60027-60027msec
WRITE: bw=95.1MiB/s (99.7MB/s), 95.1MiB/s-95.1MiB/s (99.7MB/s-99.7MB/s), io=5707MiB (5985MB), run=60027-60027msec
VM NFS in Ubuntu
4ktest: (groupid=0, jobs=16): err= 0: pid=2582: Wed Jan 31 12:55:13 2018
read : io=5766.2MB, bw=98405KB/s, iops=24601, runt= 60001msec
clat (usec): min=175, max=7686, avg=646.98, stdev=207.81
lat (usec): min=176, max=7686, avg=647.24, stdev=207.85
| 1.00th=[ 282], 5.00th=[ 342], 10.00th=[ 402], 20.00th=[ 482],
| 30.00th=[ 540], 40.00th=[ 588], 50.00th=[ 636], 60.00th=[ 692],
| 70.00th=[ 740], 80.00th=[ 788], 90.00th=[ 868], 95.00th=[ 956],
| 99.00th=[ 1208], 99.50th=[ 1336], 99.90th=[ 2480], 99.95th=[ 2992],
| 99.99th=[ 3696]
bw (KB /s): min= 4416, max= 7152, per=6.25%, avg=6154.56, stdev=564.33
lat (usec) : 250=0.14%, 500=22.51%, 750=49.42%, 1000=24.32%
lat (msec) : 2=3.48%, 4=0.12%, 10=0.01%
cpu : usr=0.76%, sys=6.68%, ctx=1483321, majf=0, minf=146
issued : total=r=1476099/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
READ: io=5766.2MB, aggrb=98404KB/s, minb=98404KB/s, maxb=98404KB/s, mint=6000 1msec, maxt=60001msec
Disk stats (read/write):
dm-0: ios=1475864/18, merge=0/0, ticks=873920/64, in_queue=875992, util=99.9 6%, aggrios=1476099/16, aggrmerge=0/2, aggrticks=884328/56, aggrin_queue=884256, aggrutil=99.91%
sda: ios=1476099/16, merge=0/2, ticks=884328/56, in_queue=884256, util=99.91%
VM NFS in Ubuntu
fio-2.2.10
Starting 16 processes
8k7030test: Laying out IO file(s) (1 file(s) / 4096MB)
Jobs: 16 (f=16): [m(16)] [100.0% done] [9054KB/4123KB/0KB /s] [1131/515/0 iops] [eta 00m:00s]
8k7030test: (groupid=0, jobs=16): err= 0: pid=2604: Wed Jan 31 12:57:23 2018
read : io=576432KB, bw=9604.7KB/s, iops=1200, runt= 60016msec
clat (usec): min=211, max=64421, avg=8819.74, stdev=7245.99
lat (usec): min=211, max=64421, avg=8820.01, stdev=7246.00
| 1.00th=[ 278], 5.00th=[ 302], 10.00th=[ 326], 20.00th=[ 402],
| 30.00th=[ 572], 40.00th=[ 7584], 50.00th=[ 9408], 60.00th=[11072],
| 70.00th=[12736], 80.00th=[14528], 90.00th=[17536], 95.00th=[20096],
| 99.00th=[28800], 99.50th=[34048], 99.90th=[44288], 99.95th=[48384],
| 99.99th=[59648]
bw (KB /s): min= 444, max= 801, per=6.26%, avg=600.84, stdev=59.27
write: io=247808KB, bw=4129.4KB/s, iops=516, runt= 60016msec
clat (msec): min=1, max=63, avg=10.47, stdev= 7.33
| 1.00th=[ 1512], 5.00th=[ 1592], 10.00th=[ 1656], 20.00th=[ 1752],
| 30.00th=[ 4832], 40.00th=[ 9024], 50.00th=[10944], 60.00th=[12480],
| 70.00th=[14144], 80.00th=[16064], 90.00th=[19072], 95.00th=[21888],
| 99.00th=[32128], 99.50th=[37120], 99.90th=[47360], 99.95th=[50432],
| 99.99th=[58624]
bw (KB /s): min= 31, max= 534, per=6.25%, avg=257.95, stdev=73.08
lat (usec) : 250=0.07%, 500=19.47%, 750=2.32%, 1000=0.13%
lat (msec) : 2=8.46%, 4=0.89%, 10=20.08%, 20=42.65%, 50=5.87%
lat (msec) : 100=0.04%
cpu : usr=0.11%, sys=0.88%, ctx=198853, majf=0, minf=168
issued : total=r=72054/w=30976/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
READ: io=576432KB, aggrb=9604KB/s, minb=9604KB/s, maxb=9604KB/s, mint=60016msec, maxt=60016msec
WRITE: io=247808KB, aggrb=4129KB/s, minb=4129KB/s, maxb=4129KB/s, mint=60016msec, maxt=60016msec
dm-0: ios=71927/30985, merge=0/0, ticks=28112/54736, in_queue=82888, util=96.70%, aggrios=72054/31008, aggrmerge=0/43, aggrticks=28396/54700, aggrin_queue=83052, aggrutil=96.57%
sda: ios=72054/31008, merge=0/43, ticks=28396/54700, in_queue=83052, util=96.57%
