With FreeNAS this has been kind of a constant woe for me. Year ago I posted this: http://forums.freenas.org/index.php?threads/freenas-not-using-all-of-the-ram.14576/#post-70620 (32GB ram not used for ARC).
I upgraded my rig last month to a proper xeon+supermicro mobo + 128GB setup, but still the ARC won't function like it should.
ARC size seems to way under what it should be. I'm only running storage services (NFS+iSCSI) on the box, so I would like to use the RAM for ARC. This is what i'm seeing at the moment:
And this is what especially worries me:
Over 3% ghost hits, even when theres plenty of RAM.
When I boot up the box I usually see the MFU warmed first to around 15-20GB. After usage (day or two) it goes down and stays down. This is what I have now:
So any ideas what could be wrong? According to Oracle ( https://pthree.org/2012/12/07/zfs-administration-part-iv-the-adjustable-replacement-cache/ ) 7/8 should be used for ARC by default. I'm not close to hitting that.
And is there any way to prioritise the MFU over MRU?
Would adding a 512GB or larger L2ARC help me better utilise the RAM?
Full specs are:
Tunables:
ARC Size: 76.64% 91.97 GiB
Target Size: (Adaptive) 91.67% 110.00 GiB
Min Size (Hard Limit): 91.67% 110.00 GiB
Max Size (High Water): 1:1 120.00 GiB
CACHE HITS BY CACHE LIST:
Anonymously Used: 7.84% 5.94m
Most Recently Used: 23.33% 17.69m
Most Frequently Used: 65.29% 49.51m
Most Recently Used Ghost: 0.63% 481.14k
Most Frequently Used Ghost: 2.91% 2.21m
last pid: 70813; load averages: 0.06, 0.05, 0.06 up 4+03:02:18 12:02:42
50 processes: 1 running, 49 sleeping
CPU: 0.1% user, 0.0% nice, 2.0% system, 0.2% interrupt, 97.7% idle
Mem: 655M Active, 10G Inact, 95G Wired, 32K Cache, 88M Buf, 19G Free
ARC: 92G Total, 693M MFU, 90G MRU, 16K Anon, 449M Header, 494M Other
Full specs are:
Xeon 2609v2
Supermicro X9SRL-F
4x 32GB of LRDIMM ECC
3x IBM m1015
20x ST4000DM000 in 2x 10-disk raidz2
Tunables:
ZFS Tunable (sysctl):
kern.maxusers 384
vm.kmem_size 130996502528
vm.kmem_size_scale 1
vm.kmem_size_min 0
vm.kmem_size_max 130996502528
vfs.zfs.l2c_only_size 0
vfs.zfs.mfu_ghost_data_lsize 96466924032
vfs.zfs.mfu_ghost_metadata_lsize 267013632
vfs.zfs.mfu_ghost_size 96733937664
vfs.zfs.mfu_data_lsize 606307840
vfs.zfs.mfu_metadata_lsize 17950208
vfs.zfs.mfu_size 727090176
vfs.zfs.mru_ghost_data_lsize 19736062976
vfs.zfs.mru_ghost_metadata_lsize 1330995200
vfs.zfs.mru_ghost_size 21067058176
vfs.zfs.mru_data_lsize 96687334912
vfs.zfs.mru_metadata_lsize 81828864
vfs.zfs.mru_size 97041267200
vfs.zfs.anon_data_lsize 0
vfs.zfs.anon_metadata_lsize 0
vfs.zfs.anon_size 16384
vfs.zfs.l2arc_norw 0
vfs.zfs.l2arc_feed_again 1
vfs.zfs.l2arc_noprefetch 0
vfs.zfs.l2arc_feed_min_ms 200
vfs.zfs.l2arc_feed_secs 1
vfs.zfs.l2arc_headroom 2
vfs.zfs.l2arc_write_boost 400000000
vfs.zfs.l2arc_write_max 400000000
vfs.zfs.arc_meta_limit 32212254720
vfs.zfs.arc_meta_used 1462661512
vfs.zfs.arc_min 118111600640
vfs.zfs.arc_max 128849018880
vfs.zfs.dedup.prefetch 1
vfs.zfs.mdcomp_disable 0
vfs.zfs.nopwrite_enabled 1
vfs.zfs.zfetch.array_rd_sz 1048576
vfs.zfs.zfetch.block_cap 256
vfs.zfs.zfetch.min_sec_reap 2
vfs.zfs.zfetch.max_streams 8
vfs.zfs.prefetch_disable 0
vfs.zfs.no_scrub_prefetch 0
vfs.zfs.no_scrub_io 0
vfs.zfs.resilver_min_time_ms 3000
vfs.zfs.free_min_time_ms 1000
vfs.zfs.scan_min_time_ms 1000
vfs.zfs.scan_idle 50
vfs.zfs.scrub_delay 4
vfs.zfs.resilver_delay 2
vfs.zfs.top_maxinflight 32
vfs.zfs.write_to_degraded 0
vfs.zfs.mg_noalloc_threshold 0
vfs.zfs.mg_alloc_failures 8
vfs.zfs.condense_pct 200
vfs.zfs.metaslab.weight_factor_enable 0
vfs.zfs.metaslab.preload_enabled 1
vfs.zfs.metaslab.preload_limit 3
vfs.zfs.metaslab.unload_delay 8
vfs.zfs.metaslab.load_pct 50
vfs.zfs.metaslab.min_alloc_size 10485760
vfs.zfs.metaslab.df_free_pct 4
vfs.zfs.metaslab.df_alloc_threshold 131072
vfs.zfs.metaslab.debug_unload 0
vfs.zfs.metaslab.debug_load 0
vfs.zfs.metaslab.gang_bang 131073
vfs.zfs.ccw_retry_interval 300
vfs.zfs.check_hostid 1
vfs.zfs.deadman_enabled 1
vfs.zfs.deadman_checktime_ms 5000
vfs.zfs.deadman_synctime_ms 1000000
vfs.zfs.recover 0
vfs.zfs.txg.timeout 5
vfs.zfs.max_auto_ashift 13
vfs.zfs.vdev.cache.bshift 16
vfs.zfs.vdev.cache.size 0
vfs.zfs.vdev.cache.max 16384
vfs.zfs.vdev.trim_on_init 1
vfs.zfs.vdev.mirror.non_rotating_seek_inc1
vfs.zfs.vdev.mirror.non_rotating_inc 0
vfs.zfs.vdev.mirror.rotating_seek_offset1048576
vfs.zfs.vdev.mirror.rotating_seek_inc 5
vfs.zfs.vdev.mirror.rotating_inc 0
vfs.zfs.vdev.write_gap_limit 4096
vfs.zfs.vdev.read_gap_limit 32768
vfs.zfs.vdev.aggregation_limit 131072
vfs.zfs.vdev.scrub_max_active 2
vfs.zfs.vdev.scrub_min_active 1
vfs.zfs.vdev.async_write_max_active 10
vfs.zfs.vdev.async_write_min_active 1
vfs.zfs.vdev.async_read_max_active 3
vfs.zfs.vdev.async_read_min_active 1
vfs.zfs.vdev.sync_write_max_active 10
vfs.zfs.vdev.sync_write_min_active 10
vfs.zfs.vdev.sync_read_max_active 10
vfs.zfs.vdev.sync_read_min_active 10
vfs.zfs.vdev.max_active 1000
vfs.zfs.vdev.larger_ashift_minimal 0
vfs.zfs.vdev.bio_delete_disable 0
vfs.zfs.vdev.bio_flush_disable 0
vfs.zfs.vdev.trim_max_pending 64
vfs.zfs.vdev.trim_max_bytes 2147483648
vfs.zfs.cache_flush_disable 0
vfs.zfs.zil_replay_disable 0
vfs.zfs.sync_pass_rewrite 2
vfs.zfs.sync_pass_dont_compress 5
vfs.zfs.sync_pass_deferred_free 2
vfs.zfs.zio.use_uma 1
vfs.zfs.snapshot_list_prefetch 0
vfs.zfs.version.ioctl 3
vfs.zfs.version.zpl 5
vfs.zfs.version.spa 5000
vfs.zfs.version.acl 1
vfs.zfs.debug 0
vfs.zfs.super_owner 0
vfs.zfs.vol.mode 2
vfs.zfs.trim.enabled 1
vfs.zfs.trim.max_interval 1
vfs.zfs.trim.timeout 30
vfs.zfs.trim.txg_delay 32
