SOLVED Aquantia Driver for TrueNAS 12.1
Rayxcer
Hey guys,
I've upgraded from FreeNAS to TrueNAS today.
Sadly, my ASUS 10GbE NIC won't show up (I assume the driver is missing).
I've tried to compile it from here, but it sadly won't work.
Error message:
I'm not really sure how to set the right compiler type, so I thought I'd ask you guys for help.
Wrong forum section. TrueNAS != TrueOS. Moved.
As for the driver, I seem to recall that it worked at one point. Check the bug tracker to see if you can find an existing ticket about this. If you don't, please file a new one, it's the kind of thing that easily gets traction with the devs if there aren't any weird showstoppers.
freqlabs
The driver is included in TrueNAS but it is an experimental development preview (since that is the only code available), therefore we do not automatically load the driver. You can manually load the driver by adding a tunable for if_atlantic_load=YES, but really don't expect this to be a high quality driver at this stage.
Rayxcer
Thanks a lot, that helped me.
gigo90
I tried to set a Tunable to load this driver, unfortunatelly after every reboot i have to load manually the driver with kldload command from the shell.
Can someone help me to find a solution?
Thanks
Samuel Tai
How are you setting the tunable? If you're manually adding the line in /boot/loader.conf, this isn't the proper way to add a tunable. The proper way is to navigate to System->Tunables in the GUI, and to add a loader tunable named if_atlantic_load with value YES. Note this tunable will only take effect at the next boot.
Droz
Where would one do this in Scale 22.02.1?
deneon2000
I have a QNAP tvs-951x with 10 GBE. I've tried configuring the tunable but it doesn't work. This has been the case with Core 12 and 13. Anyone have any idea what else I can try?
spuky
Another Post had success with scale
quick google search brought up no info what chipset they are using for the 10GB nic
