Andreas Neiser
- Oct 30, 2014
Hi all,
I worked on getting the FreeBSD ports net/aoe to compile a kernel module for FreeNAS. See this bug report,
https://bugs.freebsd.org/bugzilla/show_bug.cgi?id=194663
and the corresponding patches there in order to get a kernel module which works with an VIMAGE enabled kernel.
I then loaded the /boot/modules/aoe.ko into FreeNAS using a tunable, and set the sysctl net.aoe.iflist="em1" (assuming em1 has vblade's attached) and finally get devices ready to use in ZFS pools. To make it fully work, I needed to patch three FreeNAS files:
If you're interested in more details or have similar experiences, please share! I can also extend the description here if you want to try it yourself and can't get it working from this short description.
There are still many things do to (get the console "cec" running, test the performance/stability), but just to ask: Do you think there's any chance to get this aoe module into the FreeNAS release? Then I would write-up a more detailed feature request. And maybe you've also a better idea to enable network interfaces...
Best regards,
Andreas
Edit: Improved AoE discovery (also uploaded new patches to net/aoe bugreport), ignore dhclient...
- "/conf/base/etc/ix.rc.d/ix-zfs" Add the following lines at the top of the import_zpools() function:Code:
/sbin/sysctl -in net.aoe.iflist | /usr/bin/xargs -n 1 -J % /sbin/ifconfig % mtu 9000 up sleep 5 /sbin/sysctl -i `/sbin/sysctl -ie net.aoe.iflist` 2>/dev/null >/dev/null sleep 5 echo "========> sysctl net.aoe" /sbin/sysctl net.aoe sleep 1
- "/conf/base/etc/rc.shutdown" Comment out the complementary lines where the network interfaces are shutdown first. This, by the way, also makes ssh connections shutdown properly (and not, after it's up again, just report a broken pipe). Is there any reason why interfaces are brought down so early in FreeNAS? FreeBSD doesn't do it.
- Tell dhclient to ignore the AoE interface. Patch the file /conf/base/etc/network.subr in the routines dhcpif() and syncdhcpif(). Add the following check in both routines:Code:
if echo `sysctl -in net.aoe.iflist` | grep -q $1; then echo "Ignoring interface $1 for DHCP, it's an AOE device!" return 1 fi
Best regards,
Andreas
