Jeroen Hermans
- Aug 19, 2015
Hi all,
I have a bit of a problem. I have upgraded the NAS system to 9.3 and now the NAS is no longer working. The NAS is connected to a domain but is not the DC.
# wbinfo -t
checking the trust secret for domain SMARTHOMES via RPC calls succeeded
wbinfo -u shows the users in the domain
/var/log/log.smbd:
<CUT>
[2015/08/20 01:11:02.541740, 1] ../source3/librpc/crypto/gse.c:465(gse_get_server_auth_token)
gss_accept_sec_context failed with [ Miscellaneous failure (see text): Failed to find cifs/freenas1.smarthomes.lan@SMARTHOMES.LAN(kvno 71) in keytab MEMORY:cifs_srv_keytab (arcfour-hmac-md5)]
<CUT>
2015/08/20 01:11:07.429867, 2] ../source3/auth/auth.c:288(auth_check_ntlm_password)
check_ntlm_password: Authentication for user [Administrator] -> [Administrator] FAILED with error NT_STATUS_NO_SUCH_USER
[2015/08/20 01:11:07.430768, 2] ../source3/smbd/service.c:407(create_connection_session_info)
guest user (from session setup) not permitted to access this share (sharename)
<CUT>
/var/log/messages:
No errormessages
# host -t srv _ldap._tcp.domain.lan
_ldap._tcp.domain.lan has SRV record 0 100 389 lanserver1.domain.lan.
Any help would be greatly appreciated. If you need more information, i will be happy to provide it to you.
Thank you very much in advance.
Kind regards,
Jeroen Hermans
# wbinfo -t
/var/log/log.smbd:
<CUT>
<CUT>
<CUT>
/var/log/messages:
No errormessages
Kind regards,
Jeroen Hermans
