After update to 11.3 u5 problem in disk
Sepala
Hi to all, i need help, after update to 11.3u5 from 11.3 u4 in section storage/disks before update show pools and the name and afte not show pools name and not in menu options, whta happen?
kevinjj
Try this :
- Storage
- Pool
- ADD
- Import an existing pool
- Next
- Select No or Yes if your pool is encrypted or not
- Next
- Select your Pool
Sepala
Try this :
- Storage
- Pool
- ADD
- Next
- Next
- Select your Pool
Thanks for your help friend, an apology I think I expressed myself wrong, my pool if it is detected well, only in the disk section, previously it told me the name of each pool, after the update that tab no longer appears.
Alecmascot
It has gone in 12 too
