AES-XTS 256
Kljajoni
can someone guide me how to create encrypted volume with AES-XTS 256 encryption algorithm ? By default, FreeNAS is using AES-XTS 128 for data when you create volume from GUI, for some compliance reasons I need to change it to AES-XTS 256.
I am trying to test this on VMWare virtual machine (1 x 16Gb disk for install and swap, 5 x 5 GB disks for data RAIDZ2). I tried to use similar workaround in FreeNAS 9.3 , but I am not sure what I achieved. Unfortunately, I do not understand GEOM geli encryption behind the scene, so can someone in short can explain to me
1) What gtpid represents ?
2) What ada represents ? Is it possible to change this encryption to AES-XTS 256 ?
3) How are they related ?
geli status
										  Name  Status  Components
gptid/6150cb18-bac2-11e6-a033-000c290b314c.eli  ACTIVE  gptid/6150cb18-bac2-11e6-a033-000c290b314c
gptid/616f2340-bac2-11e6-a033-000c290b314c.eli  ACTIVE  gptid/616f2340-bac2-11e6-a033-000c290b314c
gptid/618c0d0d-bac2-11e6-a033-000c290b314c.eli  ACTIVE  gptid/618c0d0d-bac2-11e6-a033-000c290b314c
gptid/61a8c021-bac2-11e6-a033-000c290b314c.eli  ACTIVE  gptid/61a8c021-bac2-11e6-a033-000c290b314c
gptid/61c5d7e8-bac2-11e6-a033-000c290b314c.eli  ACTIVE  gptid/61c5d7e8-bac2-11e6-a033-000c290b314c
									ada0p1.eli  ACTIVE  ada0p1
									ada1p1.eli  ACTIVE  ada1p1
									ada2p1.eli  ACTIVE  ada2p1
									ada3p1.eli  ACTIVE  ada3p1
									ada4p1.eli  ACTIVE  ada4p1
geli list
Geom name: gptid/6150cb18-bac2-11e6-a033-000c290b314c.eli
State: ACTIVE
EncryptionAlgorithm: AES-XTS
KeyLength: 256
Crypto: hardware
Version: 7
UsedKey: 0
Flags: NONE
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: gptid/6150cb18-bac2-11e6-a033-000c290b314c.eli
   Mediasize: 3221135360 (3.0G)
   Sectorsize: 4096
   Mode: r1w1e1
Consumers:
   Mediasize: 3221139456 (3.0G)
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 2147549184
   Mode: r1w1e1
Geom name: gptid/616f2340-bac2-11e6-a033-000c290b314c.eli
State: ACTIVE
KeyLength: 256
Crypto: hardware
Version: 7
UsedKey: 0
Flags: NONE
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: gptid/616f2340-bac2-11e6-a033-000c290b314c.eli
   Sectorsize: 4096
   Mode: r1w1e1
Consumers:
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e1
Geom name: gptid/618c0d0d-bac2-11e6-a033-000c290b314c.eli
State: ACTIVE
KeyLength: 256
Crypto: hardware
Version: 7
UsedKey: 0
Flags: NONE
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: gptid/618c0d0d-bac2-11e6-a033-000c290b314c.eli
   Sectorsize: 4096
   Mode: r1w1e1
Consumers:
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e1
Geom name: gptid/61a8c021-bac2-11e6-a033-000c290b314c.eli
State: ACTIVE
KeyLength: 256
Crypto: hardware
Version: 7
UsedKey: 0
Flags: NONE
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: gptid/61a8c021-bac2-11e6-a033-000c290b314c.eli
   Sectorsize: 4096
   Mode: r1w1e1
Consumers:
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e1
Geom name: gptid/61c5d7e8-bac2-11e6-a033-000c290b314c.eli
State: ACTIVE
KeyLength: 256
Crypto: hardware
Version: 7
UsedKey: 0
Flags: NONE
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: gptid/61c5d7e8-bac2-11e6-a033-000c290b314c.eli
   Sectorsize: 4096
   Mode: r1w1e1
Consumers:
   Sectorsize: 512
   Stripesize: 0
   Mode: r1w1e1
Geom name: ada0p1.eli
State: ACTIVE
KeyLength: 128
Crypto: hardware
Version: 7
Flags: ONETIME, W-DETACH, W-OPEN
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: ada0p1.eli
   Mediasize: 2147483648 (2.0G)
   Sectorsize: 4096
   Mode: r1w1e0
Consumers:
1. Name: ada0p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
Geom name: ada1p1.eli
State: ACTIVE
KeyLength: 128
Crypto: hardware
Version: 7
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: ada1p1.eli
   Sectorsize: 4096
   Mode: r1w1e0
Consumers:
1. Name: ada1p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
Geom name: ada2p1.eli
State: ACTIVE
KeyLength: 128
Crypto: hardware
Version: 7
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: ada2p1.eli
   Sectorsize: 4096
   Mode: r1w1e0
Consumers:
1. Name: ada2p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
Geom name: ada3p1.eli
State: ACTIVE
KeyLength: 128
Crypto: hardware
Version: 7
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: ada3p1.eli
   Sectorsize: 4096
   Mode: r1w1e0
Consumers:
1. Name: ada3p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
Geom name: ada4p1.eli
State: ACTIVE
KeyLength: 128
Crypto: hardware
Version: 7
KeysAllocated: 1
KeysTotal: 1
Providers:
1. Name: ada4p1.eli
   Sectorsize: 4096
   Mode: r1w1e0
Consumers:
1. Name: ada4p1
   Sectorsize: 512
   Stripesize: 0
   Stripeoffset: 65536
   Mode: r1w1e1
D
dlavigne
Guest
You can't change the encryption algorithm without destroying the pool.
While you could manually configure this, it would be unsupported and would require you to be comfortable with the contents of geli(8). Bug again, it would be unsupported and you'd be on your own which would really suck if the encrypted contents became unavailable.
You could try creating a feature request to have either the default algorithm bumped up to AES-XTS 256 or to have that algorithm added as a selectable option. If you decide to create a feature request at bugs.freenas.org, post the issue number here.
