Joseph Dinsdale
- Apr 23, 2015
Hi all,
So i have reached a point now where I need to rethink my storage solution. So to begin with let me tell you what my current storage solution is and why I believe I need to change it.
So i have 3 small home NAS's, the enclosure are D-Link ShareCenter Pulse DNS-320. they have 2 hard drive bays each. 2 of these has 2x 4TB hard drives in striped raid. So this gives me 8TB on each one. The last one has 2x 2TB in striped raid, giving me 4TB on that one.
Currently the 4TB one is used for me to place backups of my Software installers along with Backup images of my computers. This drive is currently a little over half full.
My 8TB drive is used to keep backups of all my HD media I have purchased from places like iTunes, I also use it to backup any photos that I take using my camera, I keep the all the photos in a RAW format so they take up a fire bit of room. This drive currently has around 500GB until it is full.
My second 8TB drive is a direct backup of the first. I use a program called SyncToy, its a free tool made by Microsoft to Sync 2 folders. So I use that to Sync both my 8TB NAS's.
So my problem with this is when i need to upgrade to more storage i have to buy an extra enclosure + the hard drives to go with them. this is costly close to £400 ($605) to get one ready to use with 8TB storage. Also i need space to put them and they all need power and a network cable.
As I eat up a lot of storage I have decided to build my self a Storage Server. I have speced up a Server for about £500 ($756) that has 16 hot swappable hard drive bay. This will solve the problem of needing to keep buying enclosure when I need more space, all I will need to do is buy the hard drives. Also this only needs 1 power and 1 network cable.
So my current plan is to buy the server next month when I get paid. But then I come to the issue of the best way to set it up.
I will not be buying any hard drives to go with it, that will be something I buy the following month. So on the server FreeNAS will be installed on a 32GB USB 3.0 that will be plugged in to the back of the server. The I am planning on taking the 2 4TB drives from my old Backup NAS and putting them in to the server.
I will then make this in to a Pool called Media. the pool will have both the 2 4TB hard drive set-up in strip raid, to give me back the 8TB storage. Then from my old Media NAS i will transfer the data from that to this new Media Pool.
Following that i will take the other 2 4TB hard drives from the Media NAS, add them to the server and make a new Pool called Media backup, and set that up as a raid as well to give me back that 8TB storage.
Then i will look up away to make the Media Pool backup to the Media Backup Pool. The in the future when i need more storage i will buy hard drives add them to the server and extend the Pools.
So is this the best way to set-up a new Storage Solution? i will keep adding new hard drives and extending the Pools until the 16 bays are all in use.
Also what would be the best way to make the Media Pool backup to the Media Backup Pool, is there a tool in FreeNAS to do this? or should i just keep using the SyncToy from Microsoft?
