Greetings, I've been researching for a few weeks now and have been combing over all kinds of forums over NAS solutions for home. I work with storage in IT as my job, so I'm trying to balance what I want to do, to what is realistic to do in a home environment/budget. /evilgrin The home NAS/network has become the staple of the house and the wife and kids simply expect things to work at all times with little to no outages. I almost gave up and just went with a Synology unit, that way if it acted up, I could blame them and not have the wife after me for another frankenbuilt system and it follows the KISS design, however the IT guy in me wants to build something. With all that in mind, I'm looking to upgrade to have a shared storage solution to do more with ESX around HA and fault tolerance on the infrastructure at home.
Existing Clients/workload:
2 workstations, 2 laptops, 2 NUCs running openelec/XBMC, and 2 amazon fire's running XBMC, Cisco SG200-26 switch, 40Mb symetrical internet connection
ESX Server & current storage platform:
Currently I have an ASRock motherboard with an i7-3770 and 32GB ram running ESX 5.5u2 with 10 drives installed in it. It runs approximately 8 or so VMs standard. (pfsense firewall with multiple IPsec tunnels, couple of windows servers, vcenter appliance, kidsplex, sabnzb, and a few linux turnkey appliances are the standard) It gets a few additional here and there as I test various applications along the way.
Storage in ESX Server:
Future plans for my ESX hosts are 2x Shuttle SH87R6, Intel i5-4590S, 32GB RAM each to make a 2 node ESX cluster. I'll add quad port Intel Pro 1000 nic to each one with 1 additional slot for future 10Gb nic upgrade.
My future plans for the FreeNAS host are:
From all the reading, I'm concerned on both the performance on the ESX layer and if the amount of RAM is sufficient since that board tops out at 32GB. The RAM part is probably the easiest to solve in that I can just change to something in the socket 2011 line and ensure I have an avenue to expand RAM easily along the way. The ESX layer is the more complex in my mind. I'm not worried about getting massive performance in VMs as again, this is more of a test lab for my needs, and just file sharing & internet access for the family. I could add 2 drives of some sort (10k or SSD) and do a raid mirror in FreeNAS as a separate vedv/pool just for the VMs. I don't have large capacity demands inside the VMs. Also, for certain VMs, I could essentially have local storage in the ESX hosts as well to utilize. I understand that in most cases, the 1Gb network links will be the limiting factor, but I have plans to at least have 10Gb between the ESX hosts and FreeNAS storage soon.
Like I said, I've been dwelling on this for weeks, any feedback or comments are greatly appreciated, thanks!!
-k
- 4x 4TB & 3x 3TB WD Reds are RDM mapped into a Windows server for home file sharing for all clients and the VM runs mySQL for XBMC backend, Plex, and Crashplan for cloud backups
- WD 600GB 10K, WD 150GB 10k, & WD 2TB black edition all formatted as VMFS and house virtual machine files.
- Supermicro X10SL7 , Intel Xeon E3-1220V3, Crucial 32GB
- 10x 4TB WD Reds in a single raidz2 vdev (40TB RAW - 32TB usable)
- using existing Thermaltake Armor VA8000SWA case
- Corsair 850watt power supply (this might be scaled back, but I already own)
-k
