Dariusz1989
- Aug 22, 2017
Hey
I'm in a bit of a pickle.
One one hand I think of buying Qnap TS-831x which runs at 1.9/700 read/write. On the other hand for 800£ I could probably build my own little nas station.
Main usage of nas is going to be work - 1 user + few render nodes - I'm an artist.
The idea with Qnap was to get 8x raid 10 hdds 6tb each(as I already have r red pro nas ones) + m.2 ssd 1tb for cache read only / in future read/write with mirrored 1tb. - sadly qnap would never be able to max out 3gb/2gb read/write so the m.2 would be a bit of waste.
I looked around xeon-D configs and some other supermicro systems still going over them trying to find ideal one. Not sure how many cpu cores do I need?
The HDD on its own eats 10-25w. 8x 10 - 80-200W of power for cpus, add CPU 35W and I'm at 250w max. On side note I hope that there is a way to tell nas to go "idle" during the night, lets say slow speeds 100mb/read/write or something like that to conserve power. This way as it will run 24/7 I can minimize cost while I'm sleeping but allow readers to continue.
Does any1 know of any board/cpu that would allow low power combo? Looking for 8+ satas + m.2 + 2x 10sfp + possibly more sfp extensions as m.2 would reach 30gbs transfer rates with more in future... I guess pcie slots could do it but xeon-d usually have only 1 pcie slot? Bit new to xeonD...
Thanks for help.
Regards
Dariusz
EDIT - current proposal rig... still researching
Motherboard:
On second hand maybe this mobo is better, As the previous m.2 is crap then this one would allow me for pcie card.
https://www.amazon.co.uk/Supermicro-X11SSM-F-workstation-motherboards-DDR4-SDRAM/dp/B018AX44Q4
CPU :
E3-1260L v5 45W - if I can get 1
On top of that 8-16ECC ram.
Dual 10gb network or 2x 2x 10gbe for 40gb
m.2 pcie adapter
I also need to somehow get HDD for os, either USB or use pcie sata card for extra hdd?
Question is how much power would that eat ? I guess around 45W cpu, 10w m.2, no idea how much board takes and ram. 10W all ? 65W total + hdds.
Case :
http://www.fractal-design.com/home/product/cases/node-series/node-804
Thanks for help.
Regards
Dariusz
Motherboard:
CPU :
m.2 pcie adapter
Case :
