SOLVED Adobe Reader save problem
sasad000
Hi all,
When the user directly open PDF file from windows(SMB) in freenas share. And than save and replace the pdf file. That will show error message as below picture and than the original PDF file will missing,
I found the problem in "Adobe Reader DC" , the old version "Adobe Reader 11" and other pdf reader is no problem .
But "Adobe Reader DC" save in windows server is no problem.
index.php
Test on FreeNAS-9.10 , 11.1
Thanks~
pro lamer
Read-only permissions?
j0hnby
I seem to remember an annoying thing in DC causing this with network shares.....but can't remember exactly what - it was something in the security settings though....
sasad000
Problem sovled. Thank all
To disable Protected Mode:
Start Adobe Reader
Edit - Preferences - Security (Enhanced)
Uncheck Enable Protected Mode at Startup
