Additional HDDs Pool?
Fyodor
Hello! I'm having a FreeNAS file storage built at the old ATX system having 5 x 500GB HDDs set into one pool. Can I add another 4 x 3TB HDDs to the same system and mount them into separate RAID5 pool? Thanks for answering!
melloa
Everything is possible, but you need to provide more information about your system. Also check the Resources tab above and the pinned posts on this same sub-forum. See picture.
Fyodor
OK. I check resources but can't find similar topic so far. Can I generate a file giving system description?
You want Cyberjock's guide. Check my sig.
gpsguy
Active Member
Volume manager is your friend - check the docs for help.
IceBoosteR
The simple answer is yes: If your hardware has enough ports. You can have more than 1 ZFS pool in the system.
Fyodor
Great! Thanks for answering, IceBoosteR. Obviousely to install 4 HDDs into the system with 5 HDDs already present I need some investments, so I needed to know these capabilities upfront. I will go by installing Silicon Image Sil3114SATA PCI controller as existing system board doesn't have 4 SATA ports available.
Jailer
Not strong, but bad
This is a really bad idea. Search the forums for a proper HBA for your system.
Also the fact that you are considering purchasing a PCI controller card makes me suspect of the rest of your system. What is your hardware configuration that FreeNAS is currently installed on?
Fyodor
Sorry, I'm not a pro in this.
Here is my configuration:
FreeNAS-9.10.2-U1 (86c7ef5)
Gigabyte GA-M59SLI-S5
AMD Athlon(tm) 64 X2 Dual Core CPU
6 GB DDR II
ZFS vol 1: 5 x 500 GB Seagates RAIDZ1
ZFS vol 2: currently 3 x 3 TB WD Greens RAIDZ1 at ST Lab A-214 PCI SATA 4 Channel Card
Transcend 8 GB USB 2.0
Aerocool KCAS-800W
There is a 4th 3 TB WD disk (all 4 purchased together and were in use before) to organize pool 2 having 4 discs. But smartd reports on 312 unreadable sectors, so I took it out. This volume is new and empty, so I can easily reset it as needed.
Jailer
Not strong, but bad
You're under the minimum spec on RAM by 2GB. 8GB is the minimum. I hope you don't have any important data on this system.
Fyodor
Yes, I'm under, these were all DDRII chips I could find around. Before adding new discs system was working well and stable for many years (used mostly in weekends, but still). For Windows based systems we consider that RAM defines mostly the "speed" of operation. Does RAM defines also a data reliability at FreeNAS?
Fyodor
DDR2 DIMM chips are about $20 on a market. Perhaps I will go buy one next week.
Jailer
Not strong, but bad
It most definitely provides system stability. I would definitely add more especially since you are planning on expanding your pool.
Fyodor
OK, I will. How about PCI SATA card? It can support RAID 0, 1 and 0+1, but this was not an intention. Intention was to physically install all 4 additional drives. I did not install any drivers from CD or network (should I?). All HDDs are seen thru this card and can be mounted into the pool. One out of four has shown unreadable (pending) sectors right after initial installation, but does it have any relation to switching it thru PCI card - doubt it. I will need to check this disc to see if I can use it at all.
Jailer
Not strong, but bad
Can you view smart data with that card installed?
Fyodor
I have started smartctl long check for suspected HDD installed thru card. Will be out of server for a while and can check result on Thursday. I had some issues with email setup, it was not complete. How can I see smartctl results then?
Fyodor
Hello!
First of all RAM has been increased to 8 GB yesterday to meet minimum requirement. I know ECC is recommended, but this will require a full replacement, so I will try to solve it later.
On HDDs. I have four 3 TB WD Green HDDs physically connected thru ST Lab SATA Card. And I keep receiving the following system message on one of them every 30 min:
Feb 25 13:29:06 freenas smartd[2383]: Device: /dev/ada8, 312 Currently unreadable (pending) sectors
smartctl -t long /dev/ada8 command has been started and test has passed in full. If I'm not mistaken, to get the result I need -a attribute.
Here is the output:
[root@freenas] ~# smartctl -a /dev/ada8
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Green
Device Model:     WDC WD30EZRX-00MMMB0
Serial Number:    WD-WCAWZ1452699
LU WWN Device Id: 5 0014ee 25ba5a37f
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is:    Sat Feb 25 13:19:00 2017 MSK
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (52080) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 500) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   151   141   021    Pre-fail  Always       -       9416
  4 Start_Stop_Count        0x0032   091   091   000    Old_age   Always       -       9187
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   062   062   000    Old_age   Always       -       28294
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       1866
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       53
193 Load_Cycle_Count        0x0032   185   185   000    Old_age   Always       -       46284
194 Temperature_Celsius     0x0022   110   101   000    Old_age   Always       -       42
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       312
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   185   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     28288         -
# 2  Extended offline    Completed without error       00%     28277         -
                                        been run.
                                        command.
                                        power-saving mode.
No Errors Logged
May I use this ada8 to switch it into zpool or something bad is starting to happen with it?
Fyodor
Sorry for reminder, could somebody take a look at smartctl report above and let me know if HDD is still good for usage or not. I was thinking to switch 4 HDDs in mirror, but if one is out then it needs to be changed. Thank you.
The drive is full of pending sectors and is waaaaaay too hot. Not good.
IceBoosteR
as cooling for drives is everything (I also need a new case), some temperature about 35 degrees would be nice.
The pending sectors are maybe an indication for prefail, but I found this regardings the sectors:
In general, the "Current Pending Sector" is a temporary issue only. If the block will be replaced form the spare pool, the "Reallocated Sector Counter" will increment, resp. the number of spare blocks decrements.
