ZFS Noob
 - Nov 27, 2013
So, I installed FreeNAS convinced I could switch from iSCSI to NFS and get decent performance, tested it, and discovered that I was very wrong unless I want to do lots and lots of tuning and testing. Which I'm not willing to do right now, though I probably will later.
So I've pulled the SLOG out of the pool and restarted testing of NFS performance (based on the estimated completion time the SSD SLOG was making zero impact on synch write performance, interestingly), so now I'd like to add the SSD back to the pool as an L2ARC. Based on a previous discussion the consensus seems to be that a 120G L2ARC in a machine with 72G RAM is reasonable.
So I go to Storage, select the pool, enter the ZFS Volume Manager, select the SSD, inform the server that I'd like to add it as an L2ARC, then notice the big red warning on the button that says "existing data will be cleared."
This means that the data on the SSD will be wiped out in its migration from SLOG to L2ARC device, not that pool data will be impacted, right?
I'm just trying to make sure I understand what big red warnings mean before I push big red buttons...
