Add drives to current pool
Ray Milyard
I wanted to know before I start rebuilding my system. I have a 4 3tb drives right now in ZRAID1. I am adding adding 4 more of same size this weekend. I have all my media and jails on these drives right now and working how I like it. Is there a way to add these drives without needs to delete anything?
DrKK
FreeNAS Generalissimo
You cannot add them to the existing vdev.
HOWEVER, you can make another vdev, say a 4xRAID-Z1, and you can stripe that into the existing pool.
DrKK
and let me just pre-empt my colleagues: Most of my colleagues would not recommend a 4-drive Raid-Z1. I myself think it's fine, but pushing it, if those are brand new good quality drives.
m0nkey_
Any disk layout has it's pros and cons. Just make sure you have a backup.
Mirfster
I have all files backed up. That was not fun! Testing to make sure I can get all my stuff setup again on little PC I have:
If you have a full backup and all 8 drives; perhaps now would be a good time to consider making it a RaidZ2? Let DrKK keep living on the edge; he has the experience... You should still play it safe :P
P.S. don't forget to first burn in those drives before considering them ready for use. ;)
DrKK
Oh well, if he has the OPTION right now, because he's got back ups, of redoing the whole pool without RAID-Z1, then, I, as well, *would* strongly recommend that. I didn't know redoing the whole pool configuration was an option.
Ray Milyard
If you have a full backup and all 8 drives; perhaps now would be a good time to consider making it a RaidZ2? Let DrKK keep living on the edge; he has the experience... You should still play it safe :p
I was thinking putting the 8x 3tb in Raidz2 and the other 4x 2tb in Raidz1
Robert Trevellyan
Pony Wrangler
You might want to consider one RAIDZ2 vdev of 6 x 3TB, and one RAIDZ2 vdev of 2 x 3TB +4 x 2TB. The latter will initially have the capacity of 6 x 2TB, but over time replace you could replace the 2TB drives with 3TB drives to bring it to full capacity.
