paulinventome
- May 18, 2015
So I think I know the answer but I'm fairly new so I want to confirm
Aside from a RAIDZ2 pool I am building a NVMe drive for scratch work and temp files. Now NVMe's, so long as they're working, are pretty robust, AFAIK they often have parity/raid/ecc in them. So I have a card with 4xslots and I want to build an 8TB Pool.
But performance wise, even one card is fine for my network (10gbe) so I really don't need to stripe across 4 of them, and obviously despite the fact that the NVMe are pretty robust in a stripe situation is one goes down the pool goes down.
But can I just use them as one big pool but separate drives - no stripe, no mirror, no raid? So if one does go down then only the files on that stick are lost?
Kindest
Paul
Kindest
Paul
