A good way to detect IP of new headless FreeNAS
Herald.Yu
OK, I am a Chinese guy and my English is not good, please forgive me.
A few days ago, I posted an article:
How to detect FreeNAS's IP address if I have no Monitors?
In fact, the problem has not been fundamentally resolved.
The post does not aim to solve my problem, but I hope to find a good way to help more novice, let them easy to use FreeNAS .
Last day, I wrtie a tiny script by python2.7, it can detect FreeNAS IP.
#!/usr/bin/env python
# coding:utf-8
# nasip.py
import socket
#FreeNAS hostname
hostname = 'freenas'
#Print IP address in English
print 'Your FreeNAS IP address is: ' + socket.gethostbyname(hostname) + '\n'
#Print IP address in Chinese
print '¾æÊ÷NAS IPµØÖ·: ' + socket.gethostbyname(hostname) + '\n'
raw_input('Press any key to close this windows...\n°´ÈÎÒâ¼ü¹Ø±Õ´°¿Ú...')
Problems:
If FreeNAS start CIFS services, this tools can detected IP address immediately, but if CIFS stop, it will can not be detected.
QUESTION:
How to modify the FreeNAS system‘s configuration, can automatically start the CIFS service after installation?
PS: I successfully compiled FreeNAS-9.2.1.6, but I don't konw how to modify the default configuration of the source code of FreeNAS.
  • nasip.zip
enemy85
This topic has already been covered few weeks ago. Have u searched in the forum?
My answer was to enter the router config pages and see for new ip address, other reply were IPMI, use third part programs on other pc to scan the network, try to point to freenas.local from a web broser to reach the GUI ecc.
There were 6-7ways to figure this out
enemy85
Ok, i figured out it was u on the other thread :)
Knowltey
Oh my god dude, just stop and think for a second.
Well then your script isn't going to work for your fantasy user that has no monitors or ability to detect an IP, because CIFS isn't enabled by default. You have to already know the IP address of the FreeNAS box, go into the GUI and configure CIFS before your tool will even work.
You are sitting here wasting your time solving issues that do not and can not exist, and you are doing it by creating tools that only function to give you information that you already know, because you can't enable what it needs to work until you already know the information that it is going to give you.
I mean sure I can go make a batch script right now that lets me know if my computer is on. But nobody would ever use it because you have to already know that your computer is already on to use it. BTW here it is in case you want it, you may need it at the rate you're going.
@echo off
echo Yes, your computer is powered on.
pause
As I said in your other thread, if a user is so non-technical that they don't have the ability to detect the IP of a new device on their network then they have absolutely no business messing around with FreeNAS.
Whattteva
Cut him some slack lol. He said he's not looking for help and just trying to help the few others that could potentially be in the same boat.
SirMaster
You should really just look at your router to see the IPs of your machines. It should list the computer name or at worst the MAC address in which case you can look up the MAC address online to find the manufacturer of the motherboard or pcie card that is providing the Ethernet port. Failing all that just try each IP listed in your router in the web gui. You probably don't have too many if it's a home environment.
Knowltey
Nah, that was suggested in the other thread that he made and it wasn't sufficient because his fantasy user doesn't have a network.
jgreco
Resident Grinch
Well if you have no network then you don't need a network address.
Knowltey
Yeah, I really don't get what he is trying to get at. It's like he wants to teach his grandmother who has never touched a computer before how to run a FreeNAS...
jgreco
Resident Grinch
I think it's just frustrating trying to negotiate a rendezvous blind. In a slightly more complex example, you might need to arrange a certain configuration on a switchport in order to place the server on a vlan, then also need to figure out what IP was assigned. I finally got tired of logging in to multiple things just to do basic stuff and put a web server running dhcpstatus on our DHCP servers, which eliminates logging into the DHCP server to rummage around trying to find out what it assigned.
