9.3 & Replication question
BlazeStar
Hi guys,
Just installed 9.3
One of the things that really bothered me in 9.2.X was that you could only have ONE replication task.
Is it now possible to have more than one ?
Thanks!
You've never been limited to just one replication task. Not sure where you are getting the idea that you ever had that limit.
Yeah, that is definitely not fixed in 9.3. I think there is rumor they will change it a bit so you can replicate to multiple destinations in FreeNAS 10. But don't quote me on it.
BlazeStar
Ok I won't!
I can't wait for such a solution...
Right now I'm doing one replication task to a distant system, then one RSYNC task to a local, separate volume with is a set of separate drives...
jamiejunk
+1 for this. I've been needing this for years now. I'd like basically an one onsite and one offsite replica.
