9.10 Stable getting error trying to view disks
When I click "View Disks" I get the error
Unable to load /api/v1.0/storage/disk/?parent=null status:500
Found this in logfile...happens when I click
[root@ebcnas02] /var/log# tail -f nginx-access.log
10.x.x.6 - - [22/Jul/2016:08:52:41 -0500] "GET /admin/storage/disk/structure/ HTTP/1.1" 200 481 "http://ebcnas02/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/601.7.7 (KHTML, like Gecko) Version/9.1.2 Safari/601.7.7"
10.x.x.6 - - [22/Jul/2016:08:52:41 -0500] "GET /admin/storage/disk/actions/ HTTP/1.1" 200 1391 "http://ebcnas02/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/601.7.7 (KHTML, like Gecko) Version/9.1.2 Safari/601.7.7"
10.x.x.6 - - [22/Jul/2016:08:52:41 -0500] "GET /system/varlogmessages/ HTTP/1.1" 200 339 "http://ebcnas02/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/601.7.7 (KHTML, like Gecko) Version/9.1.2 Safari/601.7.7"
10.x.x.6 - - [22/Jul/2016:08:52:41 -0500] "GET /api/v1.0/storage/disk/?parent=null HTTP/1.1" 500 99 "http://ebcnas02/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/601.7.7 (KHTML, like Gecko) Version/9.1.2 Safari/601.7.7"
Sorry -didnt see not to post in this area - you can remove and I'll post to different area.
m0nkey_
Please supply more information as per the Forum Rules.
Nginx logs will do nothing to assist, since it's only acting as a reverse proxy for Django. Please provide output of dmesg, /var/log/messages, etc.
Here are the files...Didnt figure I'd get far w/ the other log but thought the calls there might point to something.
  • dmesg.txt
  • messages.txt
m0nkey_
OK, looks like your Marvell controller took a shit and one of your drives is failing.
dmesg:
mvsch9: Timeout on slot 0
mvsch9: iec 02000000 sstat 00000123 serr 00000000 edma_s 00000003 dma_c 00000000 dma_s 00000000 rs 00000001 status d0
mvsch9: iec 00000000 sstat 00000123 serr 00000000 edma_s 00000003 dma_c 00000000 dma_s 00000000 rs 00000001 status d0
(aprobe0:mvsch9:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
(aprobe0:mvsch9:0:0:0): CAM status: Command timeout
(aprobe0:mvsch9:0:0:0): Retrying command
(aprobe0:mvsch9:0:0:0): Error 5, Retries exhausted
Jul 22 05:18:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Currently unreadable (pending) sectors
Jul 22 05:18:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Offline uncorrectable sectors
Jul 22 05:48:26 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Currently unreadable (pending) sectors
Jul 22 05:48:26 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Offline uncorrectable sectors
Jul 22 05:48:26 ebcnas02 smartd[5388]: Device: /dev/ada8, previous self-test completed with error (read test element)
Jul 22 05:48:27 ebcnas02 smartd[5388]: Device: /dev/ada8, Self-Test Log error count increased from 0 to 1
Jul 22 05:48:27 ebcnas02 smartd[5388]: Warning via /usr/local/www/freenasUI/tools/smart_alert.py to root produced unexpected output (141 bytes) to STDOUT/STDERR:
Jul 22 05:48:27 ebcnas02 smartd[5388]: usage: smart_alert.py [-h] [-d DEV]
Jul 22 05:48:27 ebcnas02 smartd[5388]: smart_alert.py: error: unrecognized arguments: -s SMART error (SelfTest) detected on host: ebcnas02 root
Jul 22 05:48:27 ebcnas02 smartd[5388]: Warning via /usr/local/www/freenasUI/tools/smart_alert.py to root: failed (32-bit/8-bit exit status: 512/2)
Jul 22 05:48:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Currently unreadable (pending) sectors
Jul 22 05:48:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Offline uncorrectable sectors
Jul 22 05:48:27 ebcnas02 smartd[5388]: Device: /dev/ada8, previous self-test completed with error (read test element)
Jul 22 06:18:26 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Currently unreadable (pending) sectors
Jul 22 06:18:26 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Offline uncorrectable sectors
Jul 22 06:18:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Currently unreadable (pending) sectors
Jul 22 06:18:27 ebcnas02 smartd[5388]: Device: /dev/ada8, 19 Offline uncorrectable sectors
m0nkey_
Just to add, Marvell controllers have a bad reputation around the FreeNAS community for their long line of failures. Use either a LSI HBA or Intel SATA controller to save on headaches.
K, I'll have to see on the controller - that drive has been jacked since I created that zpool. Controller is a bit scary; I'll have to see what else is hangin' off it and go from there.
So the controller is keeping the disk list from coming up in the WebGUI?
