Quebecman
- Jan 6, 2017
So I had a look at the bug tracker and have not found anything relevant to my problem, I think. The first upgrade attempt yielded a non functioning 9-10.2 version.
Second attempt (deleted the first download from the web UI) I managed to reboot into 9-10.2, but then it enters a loop when it goes into Python scripts. Unfortunately I can't locate or figure where to find log files relating to the Python failures, so I can't quote the errors accurately.
I do remember it saying something like
Perhaps of note: I did have the system perform verification of both installs and that yielded no error.
Reverted to 9-10.1-U4 and had to import the config file since the SMB shares were "nixed" after multiple boot attempts in both versions.
So before I report any bug, perhaps I could be pointed to a potential location for Python script log? Or any suggestion.
Thanks!
ImportError urllib3
and something about too many getty
attempts and some problem with ttyv0
which prompted a 30 second pause of the system. It also outlined many lines of Python code before that, meaning to point to multiple errors in the script I imagine. Then it would relaunch into this loop and not end finishing booting up properly.Perhaps of note: I did have the system perform verification of both installs and that yielded no error.
Thanks!
