7 vs 6 Drives and RAIDZ2
SwisherSweet
I'm building up my FreeNAS server and I found a way to squeeze and extra drive into the case for a total of 7 drives instead of 6. I had planned on using RAIDZ2. Is it still adequate to use RAIDZ2 if I use 7 drives?
Also, is there any issue with having a odd number of drives with RAIDZ2?
Thank you.
Spearfoot
He of the long foot
Thank you.
You'll be fine with a 7-drive RAIDZ2 vdev. I've been running one of my servers for 2 years with 7 x 2TB drives in a RAIDZ2 array with no problems whatsoever.
Spearfoot
He of the long foot
Thanks. I am using 3TB drives, and it a year or two, I suspect I will replace with 6TB or 8TB drives as my storage needs grow and prices come down. Knowing this, is it still cool to use RAIDZ2?
Sure. The only drag is that you have to replace all drives in the RAIDZ2 pool with the larger ones before you'll see the increased capacity.
