6x 2.3Gb = 847mb raidz2 ??
carl0s
For testing I have created a virtualbox image and installed FreeNAS 8.3 beta 2.
I have added an additional 6 2.3gb disks and created a raidz2.
the zfs volume only shows as 847mb.
the zpool shows as 1.29G.
Any idea what's going on?
survive
Behold the Wumpus
Hi carl0s,
Keep in mind that FreeNAS sets aside a 2GB partition for swap on each data disk. You can disable\change this in Settings -> Advanced -> "Swap size on each drive in GiB".
-Will
carl0s
Hi carl0s,
-Will
Excellent. That explains it perfectly. Thanks!
