RAIDTester
- Jan 23, 2017
Hi all,
I've been breaking my head on this case, researching heavily for a good 40+ hours. I finally decided to reach out for help.
TL;DR; Getting 60-100MB/s read over iSCSI dual direct wired Intel 10GBE, when we're expecting 500+MB/s read performance.
I inherited this [unique?] case on a "Storinator"
Current Config
- 128GB Ram
- 2x Highpoint Rocket 750 HBA
- 30x6TB WD SE drives (30 additional, not used yet)
- ZPool of 3 vdevs x 10 disks in RAIDZ2
- 1 SSD for ZIL
- 1 SSD for L2ARC
- 2x 10GBE Intel NIC
- Direct wired to server
- Exported as single 64TB iSCSI target to Windows 2012 NTFS 64k block size
We are storing and processing backups for ~60 servers.
Files consist of a base file (usually 100GB - >1TB), and then a daily incremental backup
Nightly backups are verified every night.
Every Saturday, the nightly backups are rolled up into a weekly backup & every end of month, this is rolled up even further, consolidating and clearing out based on retention policy.
This is a really disk-intensive process, since the software needs to access the base files, and the path through all the past monthly/weekly/daily backups and write a new consolidated file.
We process up to 10 backups like this simultaneously
We were seeing dismal performance - peak 150MB/s max read.
After tons of research, tweaking and watching, repeat, over and over, I decided that the RAM is incapable of handling the huge iSCSI target and I made these changes:
I don't know if throwing more RAM at the machine will help, but we're ready to spend the money, if it will deliver.
Prevent too many queued commands to disk
sysctl vfs.zfs.vdev.max_active=10
I played with this one a LOT. Tried 1, 2 and finally tried leaving it on 10
https://forums.freenas.org/index.ph...ve-previously-vfs-zfs-vdex-max_pending.19212/
Only cache metadata
zfs set primarycache=metadata zpool
zfs set secondarycache=metadata zpool
I think this is the only thing that made a real difference so far
Allow prefetch
sysctl vfs.zfs.l2arc_noprefetch=0
Let L2ARC fill up faster
sysctl vfs.zfs.l2arc_write_max=67108864
sysctl vfs.zfs.l2arc_write_boost=67108864
Increase streams to total CPU cores
sysctl vfs.zfs.zfetch.max_streams=24
Since I made the changes - mostly to primary/secondary cache=metadata, we've been seeing a very slow rise in performance, which I attribute to the cache filling up with metadata.
I don't know if it will continue to get faster as metadata gets cached.
Am I doing this right? Should we be using CIFS instead, so that ZFS can track metadata on the actual files, instead of a giant iSCSI target that it has no idea about?
If we can't get 500-600MB/s read out of this machine, we're going to need to have to scrap this.
Anything would help at this point.
Thanks!
Current Config
- 128GB Ram
- 1 SSD for ZIL
- 1 SSD for L2ARC
Only cache metadata
Allow prefetch
Thanks!
