Hello, (first post, completely new to FreeNAS/ZFS)
I am building a new system based on Supermicro X11DPG-QT, two Xeon Scalable Silver 4114 (10 core each) processors and 64GB RAM for a mixed Home Lab / Desktop (VGA passthrough) use. I plan to have FreeNAS running as a ESXi VM (JBOD passthrough) which will serve (? iSCSI ?) as a datastore for the other VMs on the same host as well as VMs running on two diskless servers directly connected to this system by three ConnectX-3 Pro EN cards. The servers are old and with PCIe 2 slots so the max theoretical throughput is 4GigaBytes/s each.
I want to set up a fast storage system so that a lot of VMs could run and sometimes boot in parallel.
I could set up a HDD RAIDZ2 for size and SSDs caching for speed but I want to keep my HDDs in LSI-card RAID6 separate from FreeNAS until I learn and am comfortable with ZFS. I will set up automatic backup of the VMs from FreeNAS to the RAID6 several times a day so that if I mess up I don't lose everything. (FreeNAS can do that, right?)
Anyway, one of the fastest flash based storage devices right now are NVMe M.2 sticks with over 3GB/s sequential reads and a lot of IOPS. What do you think is sticking 4 of those in one card like these: Quattro M.2 NVMe SSD 410 and setting them in a RAIDZ1? Would FreeNAS be able to supply sustainable, say, 5-6 GB/s speeds. (The card is supposed to have some protection for power loss.)
Do I need this speed? No, not really. I just want to know whats possible even if I don't end up doing this setup.
Thank you for any advise you might have!
