404 page not found --> GUI offline
behzad
after installing traefik by the truecharts manual i cant acces the GUI anymore. All i get is "404 page not found". Which log file is responsible for logging this behaviour?
I also tried "service middlewared restart".
Thanks guys :)
Did you pay attention to the idea that Traefik takes over ports 443 and 80 on the server, so co-existing requires you to either:
Pick different ports for Traefik
or
Use a workaround to change the ports for your TrueNAS GUI:
panos13
As I was unable to open the link above, providing an answer here assuming you can login via ssh.
  • sudo k3s kubectl get namespaces lists the namespaces, the one you need should be ix-traefik
  • sudo k3s kubectl -n <THE_NAMESPACE> get service -o wide lists the services running, one should be traefik-tcp running on ports 80 and 443
  • sudo k3s kubectl -n <THE_NAMESPACE> delete service <THE_SERVICE> kills the service freeing the ports and allowing you to log back in.
Here's the current link to the guide:
cdog89
@danb35 - You're everywhere! Thanks for the link.
@panos13 - I did not set the Scale access ports to 81 and 444 and could not access my GUI. You're commands to kill the traefik service worked perfectly. Thanks for the help!
