I am building a new FreeNAS and upgrading from 1Gb to 10Gb NIC. I mostly do 3D design work, rendering thousands of PNG files to the NAS, then re-importing those files into video editing software. Also photoshop, reading large 3D files, assorted production tasks.
My current build is X10SL7-F / E3-1230 v3 / 32GB - this will be used as a backup NAS after I build the new one. I'll also likely leave crashplan / plex / transmission running on this machine.
Considering this for new build
X10SL7-F
E3-1265L V3 (small chassis, potential thermal constraints)
32GB ECC
6 x 12TB WD Red Plus - RAID10 (~27TB) (quietest/coolest drives - studio apartment)
2 x SSD (jails / zil / L2ARC?)
Chelsio t520 -CR 10G SFP+ card
My question: With the RAID10 + 10G connection, can I significantly increase the performance of SMB by shelling out for an X11 board with 64GB of RAM and adding L2ARC or will I already be getting close to max single-user performance with the X10 setup?
Here's my current ARC performance, but perhaps Crashplan/Plex/Transmission heavily skew this data one way or another so if I don't run those services on the new server, I would guess it will look much different.
Thanks for any thoughts on this. My first instinct is to just build the X10 version and experiment with using a couple SSDs as an SLOG and a metadata-only L2ARC
X10SL7-F
32GB ECC
root@freenas:~ # arc_summary.py System Memory: 0.98% 311.24 MiB Active, 45.71% 14.22 GiB Inact 47.97% 14.92 GiB Wired, 0.00% 0 Bytes Cache 2.32% 740.34 MiB Free, 3.02% 963.40 MiB Gap Real Installed: 32.00 GiB Real Available: 99.74% 31.92 GiB Real Managed: 97.47% 31.11 GiB Logical Total: 32.00 GiB Logical Used: 53.31% 17.06 GiB Logical Free: 46.69% 14.94 GiB Kernel Memory: 703.04 MiB Data: 93.47% 657.11 MiB Text: 6.53% 45.93 MiB Kernel Memory Map: 31.11 GiB Size: 6.79% 2.11 GiB Free: 93.21% 28.99 GiB Page: 1 ------------------------------------------------------------------------ ARC Summary: (HEALTHY) Storage pool Version: 5000 Filesystem Version: 5 Memory Throttle Count: 0 ARC Misc: Deleted: 1.76b Mutex Misses: 1.43m Evict Skips: 1.43m ARC Size: 52.05% 10.99 GiB Target Size: (Adaptive) 52.05% 10.99 GiB Min Size (Hard Limit): 17.83% 3.76 GiB Max Size (High Water): 5:1 21.11 GiB ARC Size Breakdown: Recently Used Cache Size: 67.19% 7.38 GiB Frequently Used Cache Size: 32.81% 3.60 GiB ARC Hash Breakdown: Elements Max: 1.58m Elements Current: 34.64% 547.87k Collisions: 303.80m Chain Max: 7 Chains: 32.66k Page: 2 ------------------------------------------------------------------------ ARC Total accesses: 21.49b Cache Hit Ratio: 90.63% 19.47b Cache Miss Ratio: 9.37% 2.01b Actual Hit Ratio: 90.42% 19.43b Data Demand Efficiency: 98.36% 6.86b Data Prefetch Efficiency: 1.73% 1.57b CACHE HITS BY CACHE LIST: Most Recently Used: 24.57% 4.79b Most Frequently Used: 75.19% 14.64b Most Recently Used Ghost: 0.13% 25.27m Most Frequently Used Ghost: 0.15% 29.85m CACHE HITS BY DATA TYPE: Demand Data: 34.63% 6.74b Prefetch Data: 0.14% 27.18m Demand Metadata: 64.92% 12.64b Prefetch Metadata: 0.32% 61.35m CACHE MISSES BY DATA TYPE: Demand Data: 5.60% 112.63m Prefetch Data: 76.91% 1.55b Demand Metadata: 15.98% 321.63m Prefetch Metadata: 1.52% 30.56m Page: 3 ------------------------------------------------------------------------ Page: 4 ------------------------------------------------------------------------ DMU Prefetch Efficiency: 6.40b Hit Ratio: 24.67% 1.58b Miss Ratio: 75.33% 4.82b Page: 5 ------------------------------------------------------------------------ Page: 6 ------------------------------------------------------------------------ ZFS Tunable (sysctl): kern.maxusers 2378 vm.kmem_size 33401757696 vm.kmem_size_scale 1 vm.kmem_size_min 0 vm.kmem_size_max 1319413950874 vfs.zfs.vol.immediate_write_sz 32768 vfs.zfs.vol.unmap_sync_enabled 0 vfs.zfs.vol.unmap_enabled 1 vfs.zfs.vol.recursive 0 vfs.zfs.vol.mode 2 vfs.zfs.sync_pass_rewrite 2 vfs.zfs.sync_pass_dont_compress 5 vfs.zfs.sync_pass_deferred_free 2 vfs.zfs.zio.dva_throttle_enabled 1 vfs.zfs.zio.exclude_metadata 0 vfs.zfs.zio.use_uma 1 vfs.zfs.zio.taskq_batch_pct 75 vfs.zfs.zil_maxblocksize 131072 vfs.zfs.zil_slog_bulk 786432 vfs.zfs.zil_nocacheflush 0 vfs.zfs.zil_replay_disable 0 vfs.zfs.version.zpl 5 vfs.zfs.version.spa 5000 vfs.zfs.version.acl 1 vfs.zfs.version.ioctl 7 vfs.zfs.debug 0 vfs.zfs.super_owner 0 vfs.zfs.immediate_write_sz 32768 vfs.zfs.cache_flush_disable 0 vfs.zfs.standard_sm_blksz 131072 vfs.zfs.dtl_sm_blksz 4096 vfs.zfs.min_auto_ashift 12 vfs.zfs.max_auto_ashift 13 vfs.zfs.vdev.def_queue_depth 32 vfs.zfs.vdev.queue_depth_pct 1000 vfs.zfs.vdev.write_gap_limit 4096 vfs.zfs.vdev.read_gap_limit 32768 vfs.zfs.vdev.aggregation_limit_non_rotating131072 vfs.zfs.vdev.aggregation_limit 1048576 vfs.zfs.vdev.initializing_max_active 1 vfs.zfs.vdev.initializing_min_active 1 vfs.zfs.vdev.removal_max_active 2 vfs.zfs.vdev.removal_min_active 1 vfs.zfs.vdev.trim_max_active 64 vfs.zfs.vdev.trim_min_active 1 vfs.zfs.vdev.scrub_max_active 2 vfs.zfs.vdev.scrub_min_active 1 vfs.zfs.vdev.async_write_max_active 10 vfs.zfs.vdev.async_write_min_active 1 vfs.zfs.vdev.async_read_max_active 3 vfs.zfs.vdev.async_read_min_active 1 vfs.zfs.vdev.sync_write_max_active 10 vfs.zfs.vdev.sync_write_min_active 10 vfs.zfs.vdev.sync_read_max_active 10 vfs.zfs.vdev.sync_read_min_active 10 vfs.zfs.vdev.max_active 1000 vfs.zfs.vdev.async_write_active_max_dirty_percent60 vfs.zfs.vdev.async_write_active_min_dirty_percent30 vfs.zfs.vdev.mirror.non_rotating_seek_inc1 vfs.zfs.vdev.mirror.non_rotating_inc 0 vfs.zfs.vdev.mirror.rotating_seek_offset1048576 vfs.zfs.vdev.mirror.rotating_seek_inc 5 vfs.zfs.vdev.mirror.rotating_inc 0 vfs.zfs.vdev.trim_on_init 1 vfs.zfs.vdev.bio_delete_disable 0 vfs.zfs.vdev.bio_flush_disable 0 vfs.zfs.vdev.cache.bshift 16 vfs.zfs.vdev.cache.size 0 vfs.zfs.vdev.cache.max 16384 vfs.zfs.vdev.validate_skip 0 vfs.zfs.vdev.max_ms_shift 38 vfs.zfs.vdev.default_ms_shift 29 vfs.zfs.vdev.max_ms_count_limit 131072 vfs.zfs.vdev.min_ms_count 16 vfs.zfs.vdev.max_ms_count 200 vfs.zfs.vdev.trim_max_pending 10000 vfs.zfs.txg.timeout 5 vfs.zfs.trim.enabled 1 vfs.zfs.trim.max_interval 1 vfs.zfs.trim.timeout 30 vfs.zfs.trim.txg_delay 32 vfs.zfs.space_map_ibs 14 vfs.zfs.spa_allocators 4 vfs.zfs.spa_min_slop 134217728 vfs.zfs.spa_slop_shift 5 vfs.zfs.spa_asize_inflation 24 vfs.zfs.deadman_enabled 1 vfs.zfs.deadman_checktime_ms 60000 vfs.zfs.deadman_synctime_ms 600000 vfs.zfs.debug_flags 0 vfs.zfs.debugflags 0 vfs.zfs.recover 0 vfs.zfs.spa_load_verify_data 1 vfs.zfs.spa_load_verify_metadata 1 vfs.zfs.spa_load_verify_maxinflight 10000 vfs.zfs.max_missing_tvds_scan 0 vfs.zfs.max_missing_tvds_cachefile 2 vfs.zfs.max_missing_tvds 0 vfs.zfs.spa_load_print_vdev_tree 0 vfs.zfs.ccw_retry_interval 300 vfs.zfs.check_hostid 1 vfs.zfs.mg_fragmentation_threshold 85 vfs.zfs.mg_noalloc_threshold 0 vfs.zfs.condense_pct 200 vfs.zfs.metaslab_sm_blksz 4096 vfs.zfs.metaslab.bias_enabled 1 vfs.zfs.metaslab.lba_weighting_enabled 1 vfs.zfs.metaslab.fragmentation_factor_enabled1 vfs.zfs.metaslab.preload_enabled 1 vfs.zfs.metaslab.preload_limit 3 vfs.zfs.metaslab.unload_delay 8 vfs.zfs.metaslab.load_pct 50 vfs.zfs.metaslab.min_alloc_size 33554432 vfs.zfs.metaslab.df_free_pct 4 vfs.zfs.metaslab.df_alloc_threshold 131072 vfs.zfs.metaslab.debug_unload 0 vfs.zfs.metaslab.debug_load 0 vfs.zfs.metaslab.fragmentation_threshold70 vfs.zfs.metaslab.force_ganging 16777217 vfs.zfs.free_bpobj_enabled 1 vfs.zfs.free_max_blocks 18446744073709551615 vfs.zfs.zfs_scan_checkpoint_interval 7200 vfs.zfs.zfs_scan_legacy 0 vfs.zfs.no_scrub_prefetch 0 vfs.zfs.no_scrub_io 0 vfs.zfs.resilver_min_time_ms 3000 vfs.zfs.free_min_time_ms 1000 vfs.zfs.scan_min_time_ms 1000 vfs.zfs.scan_idle 50 vfs.zfs.scrub_delay 4 vfs.zfs.resilver_delay 2 vfs.zfs.top_maxinflight 32 vfs.zfs.delay_scale 500000 vfs.zfs.delay_min_dirty_percent 60 vfs.zfs.dirty_data_sync_pct 20 vfs.zfs.dirty_data_max_percent 10 vfs.zfs.dirty_data_max_max 4294967296 vfs.zfs.dirty_data_max 3426974924 vfs.zfs.max_recordsize 1048576 vfs.zfs.default_ibs 15 vfs.zfs.default_bs 9 vfs.zfs.zfetch.array_rd_sz 1048576 vfs.zfs.zfetch.max_idistance 67108864 vfs.zfs.zfetch.max_distance 8388608 vfs.zfs.zfetch.min_sec_reap 2 vfs.zfs.zfetch.max_streams 8 vfs.zfs.prefetch_disable 0 vfs.zfs.send_holes_without_birth_time 1 vfs.zfs.mdcomp_disable 0 vfs.zfs.per_txg_dirty_frees_percent 30 vfs.zfs.nopwrite_enabled 1 vfs.zfs.dedup.prefetch 1 vfs.zfs.dbuf_cache_lowater_pct 10 vfs.zfs.dbuf_cache_hiwater_pct 10 vfs.zfs.dbuf_metadata_cache_overflow 0 vfs.zfs.dbuf_metadata_cache_shift 6 vfs.zfs.dbuf_cache_shift 5 vfs.zfs.dbuf_metadata_cache_max_bytes 505125248 vfs.zfs.dbuf_cache_max_bytes 1010250496 vfs.zfs.arc_min_prescient_prefetch_ms 6 vfs.zfs.arc_min_prefetch_ms 1 vfs.zfs.l2c_only_size 0 vfs.zfs.mfu_ghost_data_esize 1418575872 vfs.zfs.mfu_ghost_metadata_esize 4478765568 vfs.zfs.mfu_ghost_size 5897341440 vfs.zfs.mfu_data_esize 4280783872 vfs.zfs.mfu_metadata_esize 3986432 vfs.zfs.mfu_size 4791363584 vfs.zfs.mru_ghost_data_esize 479363072 vfs.zfs.mru_ghost_metadata_esize 5419480576 vfs.zfs.mru_ghost_size 5898843648 vfs.zfs.mru_data_esize 3625588736 vfs.zfs.mru_metadata_esize 212480 vfs.zfs.mru_size 5920862720 vfs.zfs.anon_data_esize 0 vfs.zfs.anon_metadata_esize 0 vfs.zfs.anon_size 1080832 vfs.zfs.l2arc_norw 1 vfs.zfs.l2arc_feed_again 1 vfs.zfs.l2arc_noprefetch 1 vfs.zfs.l2arc_feed_min_ms 200 vfs.zfs.l2arc_feed_secs 1 vfs.zfs.l2arc_headroom 2 vfs.zfs.l2arc_write_boost 8388608 vfs.zfs.l2arc_write_max 8388608 vfs.zfs.arc_meta_limit 5666084864 vfs.zfs.arc_free_target 173772 vfs.zfs.arc_kmem_cache_reap_retry_ms 1000 vfs.zfs.compressed_arc_enabled 1 vfs.zfs.arc_grow_retry 60 vfs.zfs.arc_shrink_shift 7 vfs.zfs.arc_average_blocksize 8192 vfs.zfs.arc_no_grow_shift 5 vfs.zfs.arc_min 4041001984 vfs.zfs.arc_max 22664339456 vfs.zfs.abd_chunk_size 4096 vfs.zfs.abd_scatter_enabled 1 Page: 7 ------------------------------------------------------------------------
