I am building a new FreeNAS and upgrading from 1Gb to 10Gb NIC. I mostly do 3D design work, rendering thousands of PNG files to the NAS, then re-importing those files into video editing software. Also photoshop, reading large 3D files, assorted production tasks.
My current build is X10SL7-F / E3-1230 v3 / 32GB - this will be used as a backup NAS after I build the new one. I'll also likely leave crashplan / plex / transmission running on this machine.
Considering this for new build
X10SL7-F
E3-1265L V3 (small chassis, potential thermal constraints)
32GB ECC
6 x 12TB WD Red Plus - RAID10 (~27TB) (quietest/coolest drives - studio apartment)
2 x SSD (jails / zil / L2ARC?)
Chelsio t520 -CR 10G SFP+ card
My question: With the RAID10 + 10G connection, can I significantly increase the performance of SMB by shelling out for an X11 board with 64GB of RAM and adding L2ARC or will I already be getting close to max single-user performance with the X10 setup?
Here's my current ARC performance, but perhaps Crashplan/Plex/Transmission heavily skew this data one way or another so if I don't run those services on the new server, I would guess it will look much different.
Thanks for any thoughts on this. My first instinct is to just build the X10 version and experiment with using a couple SSDs as an SLOG and a metadata-only L2ARC
X10SL7-F
32GB ECC
root@freenas:~ # arc_summary.py
System Memory:
0.98% 311.24 MiB Active, 45.71% 14.22 GiB Inact
47.97% 14.92 GiB Wired, 0.00% 0 Bytes Cache
2.32% 740.34 MiB Free, 3.02% 963.40 MiB Gap
Real Installed: 32.00 GiB
Real Available: 99.74% 31.92 GiB
Real Managed: 97.47% 31.11 GiB
Logical Total: 32.00 GiB
Logical Used: 53.31% 17.06 GiB
Logical Free: 46.69% 14.94 GiB
Kernel Memory: 703.04 MiB
Data: 93.47% 657.11 MiB
Text: 6.53% 45.93 MiB
Kernel Memory Map: 31.11 GiB
Size: 6.79% 2.11 GiB
Free: 93.21% 28.99 GiB
Page: 1
ARC Summary: (HEALTHY)
Storage pool Version: 5000
Filesystem Version: 5
Memory Throttle Count: 0
ARC Misc:
Deleted: 1.76b
Mutex Misses: 1.43m
Evict Skips: 1.43m
ARC Size: 52.05% 10.99 GiB
Target Size: (Adaptive) 52.05% 10.99 GiB
Min Size (Hard Limit): 17.83% 3.76 GiB
Max Size (High Water): 5:1 21.11 GiB
ARC Size Breakdown:
Recently Used Cache Size: 67.19% 7.38 GiB
Frequently Used Cache Size: 32.81% 3.60 GiB
ARC Hash Breakdown:
Elements Max: 1.58m
Elements Current: 34.64% 547.87k
Collisions: 303.80m
Chain Max: 7
Chains: 32.66k
Page: 2
ARC Total accesses: 21.49b
Cache Hit Ratio: 90.63% 19.47b
Cache Miss Ratio: 9.37% 2.01b
Actual Hit Ratio: 90.42% 19.43b
Data Demand Efficiency: 98.36% 6.86b
Data Prefetch Efficiency: 1.73% 1.57b
CACHE HITS BY CACHE LIST:
Most Recently Used: 24.57% 4.79b
Most Frequently Used: 75.19% 14.64b
Most Recently Used Ghost: 0.13% 25.27m
Most Frequently Used Ghost: 0.15% 29.85m
CACHE HITS BY DATA TYPE:
Demand Data: 34.63% 6.74b
Prefetch Data: 0.14% 27.18m
Demand Metadata: 64.92% 12.64b
Prefetch Metadata: 0.32% 61.35m
CACHE MISSES BY DATA TYPE:
Demand Data: 5.60% 112.63m
Prefetch Data: 76.91% 1.55b
Demand Metadata: 15.98% 321.63m
Prefetch Metadata: 1.52% 30.56m
Page: 3
Page: 4
DMU Prefetch Efficiency: 6.40b
Hit Ratio: 24.67% 1.58b
Miss Ratio: 75.33% 4.82b
Page: 5
Page: 6
ZFS Tunable (sysctl):
kern.maxusers 2378
vm.kmem_size 33401757696
vm.kmem_size_scale 1
vm.kmem_size_min 0
vm.kmem_size_max 1319413950874
vfs.zfs.vol.immediate_write_sz 32768
vfs.zfs.vol.unmap_sync_enabled 0
vfs.zfs.vol.unmap_enabled 1
vfs.zfs.vol.recursive 0
vfs.zfs.vol.mode 2
vfs.zfs.sync_pass_rewrite 2
vfs.zfs.sync_pass_dont_compress 5
vfs.zfs.sync_pass_deferred_free 2
vfs.zfs.zio.dva_throttle_enabled 1
vfs.zfs.zio.exclude_metadata 0
vfs.zfs.zio.use_uma 1
vfs.zfs.zio.taskq_batch_pct 75
vfs.zfs.zil_maxblocksize 131072
vfs.zfs.zil_slog_bulk 786432
vfs.zfs.zil_nocacheflush 0
vfs.zfs.zil_replay_disable 0
vfs.zfs.version.zpl 5
vfs.zfs.version.spa 5000
vfs.zfs.version.acl 1
vfs.zfs.version.ioctl 7
vfs.zfs.debug 0
vfs.zfs.super_owner 0
vfs.zfs.immediate_write_sz 32768
vfs.zfs.cache_flush_disable 0
vfs.zfs.standard_sm_blksz 131072
vfs.zfs.dtl_sm_blksz 4096
vfs.zfs.min_auto_ashift 12
vfs.zfs.max_auto_ashift 13
vfs.zfs.vdev.def_queue_depth 32
vfs.zfs.vdev.queue_depth_pct 1000
vfs.zfs.vdev.write_gap_limit 4096
vfs.zfs.vdev.read_gap_limit 32768
vfs.zfs.vdev.aggregation_limit_non_rotating131072
vfs.zfs.vdev.aggregation_limit 1048576
vfs.zfs.vdev.initializing_max_active 1
vfs.zfs.vdev.initializing_min_active 1
vfs.zfs.vdev.removal_max_active 2
vfs.zfs.vdev.removal_min_active 1
vfs.zfs.vdev.trim_max_active 64
vfs.zfs.vdev.trim_min_active 1
vfs.zfs.vdev.scrub_max_active 2
vfs.zfs.vdev.scrub_min_active 1
vfs.zfs.vdev.async_write_max_active 10
vfs.zfs.vdev.async_write_min_active 1
vfs.zfs.vdev.async_read_max_active 3
vfs.zfs.vdev.async_read_min_active 1
vfs.zfs.vdev.sync_write_max_active 10
vfs.zfs.vdev.sync_write_min_active 10
vfs.zfs.vdev.sync_read_max_active 10
vfs.zfs.vdev.sync_read_min_active 10
vfs.zfs.vdev.max_active 1000
vfs.zfs.vdev.async_write_active_max_dirty_percent60
vfs.zfs.vdev.async_write_active_min_dirty_percent30
vfs.zfs.vdev.mirror.non_rotating_seek_inc1
vfs.zfs.vdev.mirror.non_rotating_inc 0
vfs.zfs.vdev.mirror.rotating_seek_offset1048576
vfs.zfs.vdev.mirror.rotating_seek_inc 5
vfs.zfs.vdev.mirror.rotating_inc 0
vfs.zfs.vdev.trim_on_init 1
vfs.zfs.vdev.bio_delete_disable 0
vfs.zfs.vdev.bio_flush_disable 0
vfs.zfs.vdev.cache.bshift 16
vfs.zfs.vdev.cache.size 0
vfs.zfs.vdev.cache.max 16384
vfs.zfs.vdev.validate_skip 0
vfs.zfs.vdev.max_ms_shift 38
vfs.zfs.vdev.default_ms_shift 29
vfs.zfs.vdev.max_ms_count_limit 131072
vfs.zfs.vdev.min_ms_count 16
vfs.zfs.vdev.max_ms_count 200
vfs.zfs.vdev.trim_max_pending 10000
vfs.zfs.txg.timeout 5
vfs.zfs.trim.enabled 1
vfs.zfs.trim.max_interval 1
vfs.zfs.trim.timeout 30
vfs.zfs.trim.txg_delay 32
vfs.zfs.space_map_ibs 14
vfs.zfs.spa_allocators 4
vfs.zfs.spa_min_slop 134217728
vfs.zfs.spa_slop_shift 5
vfs.zfs.spa_asize_inflation 24
vfs.zfs.deadman_enabled 1
vfs.zfs.deadman_checktime_ms 60000
vfs.zfs.deadman_synctime_ms 600000
vfs.zfs.debug_flags 0
vfs.zfs.debugflags 0
vfs.zfs.recover 0
vfs.zfs.spa_load_verify_data 1
vfs.zfs.spa_load_verify_metadata 1
vfs.zfs.spa_load_verify_maxinflight 10000
vfs.zfs.max_missing_tvds_scan 0
vfs.zfs.max_missing_tvds_cachefile 2
vfs.zfs.max_missing_tvds 0
vfs.zfs.spa_load_print_vdev_tree 0
vfs.zfs.ccw_retry_interval 300
vfs.zfs.check_hostid 1
vfs.zfs.mg_fragmentation_threshold 85
vfs.zfs.mg_noalloc_threshold 0
vfs.zfs.condense_pct 200
vfs.zfs.metaslab_sm_blksz 4096
vfs.zfs.metaslab.bias_enabled 1
vfs.zfs.metaslab.lba_weighting_enabled 1
vfs.zfs.metaslab.fragmentation_factor_enabled1
vfs.zfs.metaslab.preload_enabled 1
vfs.zfs.metaslab.preload_limit 3
vfs.zfs.metaslab.unload_delay 8
vfs.zfs.metaslab.load_pct 50
vfs.zfs.metaslab.min_alloc_size 33554432
vfs.zfs.metaslab.df_free_pct 4
vfs.zfs.metaslab.df_alloc_threshold 131072
vfs.zfs.metaslab.debug_unload 0
vfs.zfs.metaslab.debug_load 0
vfs.zfs.metaslab.fragmentation_threshold70
vfs.zfs.metaslab.force_ganging 16777217
vfs.zfs.free_bpobj_enabled 1
vfs.zfs.free_max_blocks 18446744073709551615
vfs.zfs.zfs_scan_checkpoint_interval 7200
vfs.zfs.zfs_scan_legacy 0
vfs.zfs.no_scrub_prefetch 0
vfs.zfs.no_scrub_io 0
vfs.zfs.resilver_min_time_ms 3000
vfs.zfs.free_min_time_ms 1000
vfs.zfs.scan_min_time_ms 1000
vfs.zfs.scan_idle 50
vfs.zfs.scrub_delay 4
vfs.zfs.resilver_delay 2
vfs.zfs.top_maxinflight 32
vfs.zfs.delay_scale 500000
vfs.zfs.delay_min_dirty_percent 60
vfs.zfs.dirty_data_sync_pct 20
vfs.zfs.dirty_data_max_percent 10
vfs.zfs.dirty_data_max_max 4294967296
vfs.zfs.dirty_data_max 3426974924
vfs.zfs.max_recordsize 1048576
vfs.zfs.default_ibs 15
vfs.zfs.default_bs 9
vfs.zfs.zfetch.array_rd_sz 1048576
vfs.zfs.zfetch.max_idistance 67108864
vfs.zfs.zfetch.max_distance 8388608
vfs.zfs.zfetch.min_sec_reap 2
vfs.zfs.zfetch.max_streams 8
vfs.zfs.prefetch_disable 0
vfs.zfs.send_holes_without_birth_time 1
vfs.zfs.mdcomp_disable 0
vfs.zfs.per_txg_dirty_frees_percent 30
vfs.zfs.nopwrite_enabled 1
vfs.zfs.dedup.prefetch 1
vfs.zfs.dbuf_cache_lowater_pct 10
vfs.zfs.dbuf_cache_hiwater_pct 10
vfs.zfs.dbuf_metadata_cache_overflow 0
vfs.zfs.dbuf_metadata_cache_shift 6
vfs.zfs.dbuf_cache_shift 5
vfs.zfs.dbuf_metadata_cache_max_bytes 505125248
vfs.zfs.dbuf_cache_max_bytes 1010250496
vfs.zfs.arc_min_prescient_prefetch_ms 6
vfs.zfs.arc_min_prefetch_ms 1
vfs.zfs.l2c_only_size 0
vfs.zfs.mfu_ghost_data_esize 1418575872
vfs.zfs.mfu_ghost_metadata_esize 4478765568
vfs.zfs.mfu_ghost_size 5897341440
vfs.zfs.mfu_data_esize 4280783872
vfs.zfs.mfu_metadata_esize 3986432
vfs.zfs.mfu_size 4791363584
vfs.zfs.mru_ghost_data_esize 479363072
vfs.zfs.mru_ghost_metadata_esize 5419480576
vfs.zfs.mru_ghost_size 5898843648
vfs.zfs.mru_data_esize 3625588736
vfs.zfs.mru_metadata_esize 212480
vfs.zfs.mru_size 5920862720
vfs.zfs.anon_data_esize 0
vfs.zfs.anon_metadata_esize 0
vfs.zfs.anon_size 1080832
vfs.zfs.l2arc_norw 1
vfs.zfs.l2arc_feed_again 1
vfs.zfs.l2arc_noprefetch 1
vfs.zfs.l2arc_feed_min_ms 200
vfs.zfs.l2arc_feed_secs 1
vfs.zfs.l2arc_headroom 2
vfs.zfs.l2arc_write_boost 8388608
vfs.zfs.l2arc_write_max 8388608
vfs.zfs.arc_meta_limit 5666084864
vfs.zfs.arc_free_target 173772
vfs.zfs.arc_kmem_cache_reap_retry_ms 1000
vfs.zfs.compressed_arc_enabled 1
vfs.zfs.arc_grow_retry 60
vfs.zfs.arc_shrink_shift 7
vfs.zfs.arc_average_blocksize 8192
vfs.zfs.arc_no_grow_shift 5
vfs.zfs.arc_min 4041001984
vfs.zfs.arc_max 22664339456
vfs.zfs.abd_chunk_size 4096
vfs.zfs.abd_scatter_enabled 1
Page: 7
