3-way mirror ?
anankeo
For added availability I'm considering building a RAID0 pool on top of several 3 way-RAID1 vdevs built with 4TB hard drives.
However I'm wondering :
- Will the read performances be better compared to a 2-way mirror ?
- What if a second drive fails in the same vdev during the reconstruction ? Does ZFS handle this transparently (ie uses the remaining healthy drive for reconstruction without downtime) ?
- How does ZFS reconstruct a failed raid1 vdev if it has 2 available mirror drives ? Will it use both drives, reducing by half the access on the mirrored drives, or will it use only one drive ?
Thanks ;)
Arwen
Yes, barring other bottlenecks like network or PCIe lanes to the disk controller chip.
Yes.
Thanks ;)
Sorry, don't know.
Robert Trevellyan
Pony Wrangler
You can't do nested RAID levels with ZFS. Pools are made of vdevs, and vdevs are made of physical drives. Redundancy is present at the vdev level.
EDIT: now I see you're talking about striped vdevs. OK, that's how ZFS works, carry on ...
:oops:
(but using proper ZFS terminology would help to avoid confusion)
anankeo
Yes.
Sorry, don't know.
Thanks Arwen, I guess this is something I can try and see if both drives are working during the reconstruction.
anankeo
:oops:
Hehe sorry for the confusion
