eliminatrix
- Apr 3, 2018
Hi All,
This setup of mine might sound a bit stupid but I can't figure out why it's not working. In my FreeNAS box, I have a 4-port gigabit NIC HP card. I had to use it for ESXI and I decided to keep it in for FreeNAS. One port connects to my modem for internet connectivity, and two other ports are connected directly to another computer (Corei5).
For some reason, I can only get ONE connection to Corei5 going at any one time.
I've assigned static IP addresses for the two connections to Corei5
Corei5 #1 = 10.25.1.1 / FreeNAS = 10.25.1.2
Corei5 #2 = 172.16.10.1 / FreeNAS = 172.16.10.2
In the network config section of FreeNAS, if I assign a static IP address to one interface, the other one drops out.
EG: I'll configure interface igb1 for 10.25.1.2. apply it, I'll then go to configure interface igb3 for 172.16.10.2, apply it = goes back to interface screen and igb1 has reset and dropped it's configuration, reset to 0.0.0.0
What's going on? Could really use some help here!
Thanks!
Thanks!
