Hi guys,
I had one of my tanks go down (3x segate 1TB stack). I hear the click of death on one of the drives so I'm writing that one off normally I should be able to recover and I have a spare 1.5TB that I was going to use to correct but I'm really stuck.
1) The system would not boot with that stack plugged in. I would get a Fatal trap 12: page fault while in kernel mode fault during boot at a g_io_deliver. Fault code: supervisor read data, page not present.
So, I booted the system w/o those drives plugged in, and was able to remove the tank (detach w/o erase).
2) When I attempted to import that volume from the GUI it would error out. So I tried from the command line and i get this:
From the GUI i see two of the three drives (ada2 and ada6) listed there and am not seeing any issues there, however, I do see an alarm:
CRITICAL: Dec. 16, 2018, 1:06 a.m. - Device: /dev/ada6, 4 Currently unreadable (pending) sectors
CRITICAL: Dec. 16, 2018, 1:06 a.m. - Device: /dev/ada6, 4 Offline uncorrectable sectors
Am i totally hosed? I am not sure why the second drive says faulted/corrupted data. As far as I know it was only a single drive failure and the likely hood of two failures at the same time seem low but maybe this is what happened?
Appreciate any support on what I might be able to do. Could I manually try to use another tool to replicate the data on ada6? What options do I have?
root@freenas:/ # zpool import
   pool: Tank1
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
    devices and try again.
   see: http://illumos.org/msg/ZFS-8000-3C
    Tank1                                           UNAVAIL  insufficient replicas
      raidz1-0                                      FAULTED  corrupted data
        2440255289171413541                         FAULTED  corrupted data
        3317451196795012811                         UNAVAIL  cannot open
        gptid/b9da1cfb-a5c3-11e7-89e0-605040302010  ONLINE
