mervincm
- Mar 21, 2014
I am quite new to TrueNAS, moving over from Synology based systems. I installed the original TrueNAS scale beta, but then got busy and didn't get a chance to pick it up again till today. I updated to the current beta via GUI without incident. I created a mirror pool from a pair of Optane disks, and another from a pair of SATA SSDs, both completed without incident. When I tried to make a pool RAID-Z2 or RAID-Z from all six disks, it errors out
('one or more vdevs refer to the same device, or one of\nthe devices is part of an active md or lvm device',)
Searching I found references that this can be solved via using the quick wipe option on each individual HDD, but it hasn't helped me here.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 97, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/lib/python3/dist-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1098, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1186, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/zfs.py", line 112, in do_create
zfs.create(data['name'], topology, data['options'], data['fsoptions'])
File "libzfs.pyx", line 404, in libzfs.ZFS.__exit__
File "libzfs.pyx", line 1304, in libzfs.ZFS.create
libzfs.ZFSException: one or more vdevs refer to the same device, or one of
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 382, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 418, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1092, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1182, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 827, in do_create
raise e
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 764, in do_create
z_pool = await self.middleware.call('zfs.pool.create', {
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1305, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1262, in _call
File "/usr/lib/python3/dist-packages/middlewared/service.py", line 827, in create
rv = await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1270, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1276, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1203, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1177, in run_in_executor
libzfs.ZFSException: ('one or more vdevs refer to the same device, or one of\nthe devices is part of an active md or lvm device',)
